Driveshaft center bearing flange nut
Old 07-05-2005, 10:11 AM
DaveInDenver's Avatar
Anyone know if the stake nut that retains the flange holding the carrier bearing on a 2-piece driveshaft is the same or similar to the pinion nut on the third? I need to replace the carrier bearing, but apparently no one has the nut in stock. I have an extra pinion nut and was hoping that it was the same diameter and pitch, but that the staking shoulder is taller or something.
Old 07-05-2005, 10:36 AM
4Crawler's Avatar
Yep, should be the same thing.
Old 07-06-2005, 06:53 AM
Took it all apart last night and the pinion nut I have did not appear to be the same size. I did not take my old companion flange nut off to compare, though. I'm gonna wait on the one my parts guy ordered and compare them before proceeding.
Old 07-06-2005, 07:27 AM
4Crawler's Avatar
Interesting, the t-case and pinion flange nuts are all the same size, 30mm nuts. Never seen the center support bearing nut, though.
justdifferentials
Just Differentials
14
09-24-2017 08:32 PM
JimiJams
08-07-2015 01:36 PM
Up&Down
08-05-2015 06:20 AM
TDonkey
07-26-2015 10:14 AM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
Quick Reply: Driveshaft center bearing flange nut
