Downey front truss pictures
Old 03-08-2004, 01:54 PM
amusement's Avatar
As requested I have posted some info about Downey's front truss and some iamges to boot.
As mentioned in Downey's 2001 catalog page 96
1986-95 4WD pickup and 4runner IFS front truss
You have probably notice the IFS lower control arms swing from below the frame on vertical drop arms. Once the lower control arms become totally bottomed-out in a violent or unexpected off road maneuver, the lower control arms, working through the leverage of the vertical drop will throw the front-end out of alignment, and prevent realignment until after your visit a frame ship, The front side of your lower control arms has a factory installed tie bar. The rear side of the problem area and needs the Downey truss. This is a silver zinc plated tie bar with mounting bolts. Drilling is required.
From Toyota Truck & Land Cruiser by Moses Ludel page 337
Downey Off-Road's IFS 4WD control arm truss brace is a must item for any off-pavement four-wheel drive user -- especially trucks with oversize tires. Frame shops often see stock suspension systems with their lower control arms and vertical frame supports spread apart. This truss aims at protecting your truck's frame, suspension and steering linkage.
Here are some pictures from my 95 Toy pickup with Downey Off-Road's front truss.
Image 1
Image 2
Image 3
Image 4
Image 5
Old 03-08-2004, 02:01 PM
Waterboy's Avatar
Thanks for the pics. Looks better then some other makes I've seen.
Old 03-08-2004, 02:02 PM
KING's Avatar
So the question everyone wants to get at: how much for the truss?
Old 03-08-2004, 02:07 PM
amusement's Avatar
39.95 USD in 2002
Today the cost is around 45 USD call Downey to get an accurate price.
There number is 562-919-9494.
Old 03-08-2004, 02:34 PM
KING's Avatar
Reasonable enough to make it my next mod on my list.
Old 03-08-2004, 03:14 PM
Mikronized's Avatar
if you plan on instilling a lift anytime soon then you may want to hold off on installing the truss. My superlift kit came with one piece control arm drops/truss, so if you have a kit that comes like that then you won't need the downey one.
Flying91
45
04-11-2024 04:39 PM
XtraCab
04-12-2020 05:25 AM
jasonty
41
12-23-2018 01:00 PM
ksmudrunner99
07-21-2015 05:33 AM
TokyoD23
07-12-2015 06:01 AM
Quick Reply: Downey front truss pictures
