Door Lock Help!! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-19-2006, 05:25 PM   #1 (permalink)
bigacuralvr's Avatar
Send a message via AIM to bigacuralvr Send a message via Yahoo to bigacuralvr
Door Lock Help!!
Ok, heres my problem:
My doors will not lock from the door switch, to the key, to the alarm, and even with the pass side lock button. BUT...the unlock works fine.
Now, I took apart the door, and I am getting a negative lock signal when I hit the lock button, so the switch is working fine.
I looked for fuses, and checked here, to see if anyone had had this problem, and couldn't find anything!!
Are there separate fuses, or relays somewhere else in the turck besides above my knee, and under the hood??
I have a Viper 791xv, that I am 100% ok!
Any advice would be great!
Thanks,
Brett
__________________
Current:
94 4Runner SR5 3.Slow...for now.
SOLD. :(
99 4Runner Limited SuperCharged, Hood Scoop, Westin Bull Bar, PIAA 510's, PIAA GTX Heads and Fogs, ProComp 1069's, True Flow Intake, Jardine Exhaust, Red Interior Lights, Other Little Stuff...
bigacuralvr is offline
Old 07-19-2006, 10:51 PM   #2 (permalink)
Could it be a relay??
Brett
__________________
Current:
SOLD. :(
Old 07-19-2006, 11:56 PM   #3 (permalink)
profuse007's Avatar
POWER LOCK BROWN/WHITE (TYPE B) @ PLUG BELOW FUSEBOX
POWER UNLOCK GREEN/YELLOW and BLUE/YELLOW (TYPE B) Use both @ PLUG BELOW FUSEBOX, See NOTE *1
look at those wires and tell me how the 791xv is wired. how long did ago this occur?
notice the unlock has two wires, grn/ylw is for unlock and blue/ylw is for unlock detection. take a pic of it. could be wiring the wrong way thatll affect the system.
__________________
Tran,
oO 4runner - Millenium Silver
WTB: 01-02 4runner right(pass.) taillight .,~??▼.,~??▼.,~??▼
WTB: Hood wind deflector
profuse007 is offline
Old 07-20-2006, 03:03 PM   #4 (permalink)
I have the lock to the brn/whit, and the 2 unlocks are diode isolated. It has been on the truck for about 2 years now, without a problem. Went to the dealer...and they hadn't a clue what was wrong!!
Anybody have any ideas????
Brett
__________________
Current:
SOLD. :(
Old 07-21-2006, 09:58 AM   #5 (permalink)
please...Im dieing here!! I took out the fuse block, and there isn't an "integration relay" as found on this website through a search. I guess I'll get a new fuse box, and see if that fixes it.
Brett
__________________
Current:
SOLD. :(
Old 07-21-2006, 10:08 AM   #6 (permalink)
profuse007's Avatar
heres a test you can do to be sure that the fuse block is workin properly:
at the lock wire, see if youre gettin neg while turning the key of the drivers door to lock. btw, pressing the lock button will not work on these wires.
if youre gettin a negative but no actuator wanting to move, theres possible that ur integrated circuit is affected. btw, this is pretty rare that this occur.
__________________
Tran,
Old 07-21-2006, 11:14 AM   #7 (permalink)
Yeah...everyone Ive talked to has no idea!!
It meters 12v, but then ground as soon as I hit both the door switch, or using the door cylinder. I can hear the relay click slightly when I hit the lock button, but it's nothing like the unlock click.
So, the lock/unlock relay is built into the fuse box huh? I looked at it yesterday...and figured so, but wasn't 100% sure.
Brett
__________________
Current:
SOLD. :(
Old 07-21-2006, 08:13 PM   #8 (permalink)
profuse007's Avatar
drivers drlk actuator wire: 12v (+)
Lock Motor blue/white driver kick blue 12 pin plug
Unlock Motor pink/green driver kick blue 12 pin plug
meter that for final possibility.
__________________
Tran,
Old 07-30-2006, 08:30 AM   #9 (permalink)
doors wont lock
I have the same problem.However, I do not have an aftermarket alarm.All is factory. I checked the fuses.They are fine. Is there a door lock relay somewhere that I could change?
vango is offline
Old 08-07-2006, 09:11 PM   #10 (permalink)
Stupid, but mine just "started working"...I called and talked to one of the greatest service guys ever, and he said its either of the 3:
1. a bad actuator (But only one door wouldn't work...)
2. I loose lock rod in the drivers door
3. A Broken/Cut wire in the drivers door jamb loom thing
I just got back from NC (TONS of sweet Runners in the OBX part, btw!!)
Brett.
__________________
Current:
SOLD. :(
Old 08-07-2006, 09:48 PM   #11 (permalink)
fireteacher's Avatar
i had the same thing happen. pissed me off and all i did was squeeze the piece that goes through the door and into the dash (some type of tubing with wires behind it) and smoved it around. worked ever since. prob should get in there and see WTF but when it F's up again.
also i have the 791x
__________________
Shaun
99 limited 4runner 3.4L
MODS: TJM-17/Sonoran shackle hangers/driving lights - DIFF Breather - Sliders - Cobra 19 ULTRA III cb and 3ft. Wilson ant - 265/75/16 Definity Dakota A/T - "SATOSHI MOD" - All Weather Mats - Locker Mod - Fog Light Mod - Vortex Classic Muffler
My profile http://yotatech.com/showthread.php?t=96117
fireteacher is offline
Tags
door, lock, vortex
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Power door lock Neaners 86-95 Trucks & 4Runners 0 11-03-2006 11:20 PM
Door lock Problem cimahar 95.5-2004 Tacomas & 96-2002 4Runners 2 12-25-2005 05:04 PM
Remote Door Lock Gentleman 95.5-2004 Tacomas & 96-2002 4Runners 7 10-09-2003 05:40 AM
Door lock Mindburnt Maintenance & Repair Archives 2 09-29-2003 05:52 PM
2009 InternetBrands, Inc.
