door hinge replacement
Old Nov 18, 2004 | 10:21 AM
Greg'sToy's Avatar
anybody ever replaace the drivers side door hinges? mine are loose, and preventing the door from closing easily. any tips? or should i have someone else do it..? i've never done them before.
Old Nov 18, 2004 | 11:33 AM
Glenn's Avatar
I bought a set from a member on this board and replaced one of mine. It is pretty easy to do ... just support the bottom of the door and remove/replace one hinge at a time. They aren't cheap new, and are about $20-25 each at a salvage yard. Better yet, see if someone on the board is parting out a truck and see if their hinges are any good.
Old Nov 18, 2004 | 11:34 AM
eric-the-red's Avatar
Haven't done it on my Toyota, but I helped a neighbour do his a while ago, one of those 1980s 2-door Fords with the huge doors. It wasn't too hard, but you will need someone else to help hold the door. Before you unbolt the old hinges mark around the outside of them, fine tip felt marker works well. That makes it easier to get them lined up again. Once you get the new ones on you may have to do some fine adjustment.
Jun 1, 2021 01:51 PM
sandyota
Feb 4, 2021 11:16 AM
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Cplmike
Jul 8, 2015 08:47 PM
