does the PCV have to be OEM?
Old Feb 13, 2005 | 06:51 AM
Teamsobaco's Avatar
Can I buy one at western auto or pep boys or does this have to be toyota?
Old Feb 13, 2005 | 07:27 AM
Glenn's Avatar
It doesn't have to be Toyota. I have never bought a Toyota PCV valve in 10+ years of owning Toyota trucks and have never had a problem with aftermarket ones.
Old Feb 13, 2005 | 07:59 AM
SLC Punk's Avatar
It doesn't have to be OEM.
I prefer to use OEM parts, but you will be ok with an aftermarket one.
Old Feb 13, 2005 | 08:35 AM
wvuviv30's Avatar
what engine are you workign on?
3vze = . there is an intake manifold in the way of changing it . I beleive the PCV valce is causing my excessive oil burning.
Old Feb 13, 2005 | 01:29 PM
Teamsobaco's Avatar
Whoo Hooo...changed out the pcv Valve in about 1/2 Hour on my 3.slow...also did the Marvel Mystery oil treatment from the brake booster line...I can smoke the tires now!!!! Also a long time problem (before PCV and MMO)...Can anyone tell me why I get an idiot light intermitently??? I pulled the code think it is a 71...I have done most everything and ohmed everything according to the FSM....Seems like the light goes out most when running high test gasoline.....do I need to change out the o2 sensor?
shredder4286
Oct 1, 2015 01:09 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
puddlepirate
Sep 29, 2015 08:02 PM
4runnerFireman
Sep 29, 2015 06:24 AM
voiddweller
Sep 28, 2015 11:21 PM
