Do your trucks/4runners wander?
Old 05-12-2007, 09:13 PM
Mad Chemist's Avatar
Hey, I'm up in Lake Forest Park. Also have the same issue with my '98. Front end alignment helped a bit. My Revo's seem to wander on me alot more than when I've got the 33" MTs on the rig. I'm thinking about trying new bushings on the a-arms to see if that helps.
Old 05-13-2007, 08:28 PM
RunnerUp's Avatar
my truck used to wander when my mud terrains had about 40k on them, replaced them with terragrapplers and problem was gone
Old 05-13-2007, 09:41 PM
nick-m's Avatar
Mine drives straight on even terrain, but Lord help me if I hit a big pothole at highway speed - that usually throws it hard in one direction or the other. I have new and properly balanced tires, so it's between the steering bushings, which are relatively inexpensive to replace, and the suspension being shot, which I know for a fact is.
Old 05-14-2007, 12:16 PM
CLin9383's Avatar
wa4x4 any update? my steering wheel is wobblying alot and when i hit bumps i feel like im on ice bouncing around!!
Old 05-14-2007, 12:33 PM
  #25
Gerdo's Avatar
Over the last couple of years I have replaced: Steering Rack, Inner and outer Tie Rods, Poly Steering Rack Bushings, Poly front Anti-Sway Bar mounts and end bushings, Rear Anti-Sway Bar end bushings. I also keep the tires rotated and ballanced. My Bilsteins are in good shape also. It rides great and goes straight down the highway better than most new cars.
Old 05-14-2007, 12:48 PM
  #26
cackalak han's Avatar
My 98 wandered like crazy, too. Hitting a pot hole at anything over 40mph sent the front end hopping all over the place.
I switched out the struts/shocks, but didn't remedy the problem. I was going to get new steering rack bushings, but it was totalled before I could do that. Also did new sway bar bushings, endlinks, but didn't help.
It's probably the steering rack bushings, ball joints or tie-rods.
Kcannaday
40
03-26-2021 05:59 PM
Ricu_air
09-21-2015 08:09 AM
Yotadawgjr
10
08-23-2015 10:51 AM
ashersullivan88yota
08-23-2015 12:49 AM
ashersullivan88yota
08-12-2015 01:16 PM
Quick Reply: Do your trucks/4runners wander?
