Do Hella 500's on the front bumper affect engine temps + mileage?
Old 12-06-2008, 09:04 AM
BushPig's Avatar
Wondering if installing Hella 500's on the front bumper of your 3rd Gen 4Runner, just inside of the headlights, affects airflow over the radiator?
I'm guessing that if anything, the thermostat is forced to stay open longer...?
Also, do you experience reduced mileage on the highway?
Thanks!
Old 12-06-2008, 09:16 AM
drguitarum2005's Avatar
Location: Houston (home), Atlanta (school), Cincinnati (work)
no and no
the airflow IS affected, yes, because of basic fluid mechanics, but its so negligible that you won't be able to tell. the same applies for the gas mileage.
89silverpu's Avatar
Originally Posted by drguitarum2005
no and no
x2...
Old 12-06-2008, 09:31 AM
Staff
DeathCougar's Avatar
My 2000 4Runner had the exact same lights in the front bumper. It did not affect the truck one iota.
Old 12-06-2008, 09:35 AM
BushPig's Avatar
Thanks for the info! Much appreciated.
How do you guys mount the Hella 500's? I want them to sit nice and tight on the bumper --- I definitely don't want them to "flop" around on the highway etc.
Maybe there's a simple way to mount and de-mount them, so I can take them off when they aren't being used... ?
Old 12-06-2008, 09:56 AM
deines97runnah's Avatar
Havent got any issues.
Old 12-06-2008, 10:07 AM
pius222's Avatar
Used 2 "L" shaped steel plate as reinforcement.
[IMG][/IMG]
[IMG][/IMG]
Old 12-06-2008, 11:27 AM
3w41d's Avatar
pretty sure the 99+ fatlip bumpers have some tabs under the plastic in front of the grille
Old 12-06-2008, 11:49 AM
crolison's Avatar
I had 4 of them, and no and no...
i just drilled into my metal bumper to mount them.
Old 12-06-2008, 12:00 PM
Gerdo's Avatar
I had a pair of KC pencil beams on a per-runner style bar. They were too deep to just mount to the bumper. The 500s are shalow enough that you can just drill thru the steel bumper and bolt them on. The biggest problem that I had was that the "bumper" is just a piece of bodywork (the real bumper is the black steel thing under the lower valance) and the added weight and the tight focus of the lights amplified the fact that the "bumper" would shake all over the place. You probably won't have any problems with just the Hellas.
Old 12-06-2008, 04:44 PM
j-man's Avatar
Your fine, dont worry. I mounted 3 8" long ranges on my light bar - see below
You'll find out that if you take your rig off the pavement and your lights are mounted to the bumper, they will shake soo bad it'll make you dizzy while driving.
Attached Thumbnails Do Hella 500's on the front bumper affect engine temps + mileage?-20004runnersleeksterlightbar-003-resize.jpg
Old 12-06-2008, 05:07 PM
Rock Slide's Avatar
I'm running 2 Hella 4000s on a TJM T15...all is good here. No issues what so ever.
Old 12-07-2008, 04:22 AM
wormhole's Avatar
Agreed. I had one of the lights shake loose and had to tigthen it a few difference times.
No problems with air flow or gas milage
Old 12-09-2008, 05:00 AM
mkgarrison5's Avatar
i was thinking of mounting some 500's as well... the issue with the shaking is what bothers me.... those of you who have them mounted on stock bumpers how are they offroad and if they do not shake how did you mount them? some tips would be great
Old 12-09-2008, 08:56 AM
Gerdo's Avatar
Mine shook on the stock bumper with the extra weight of the pre-runner bar.
This is how I fixed the problem.
Old 12-10-2008, 08:29 AM
not all of us can afford a new bumper lol
Old 12-10-2008, 08:43 AM
scuba's Avatar
This is how I did Mine...
https://www.yotatech.com/forums/f116...nstall-156311/
Old 12-10-2008, 10:08 AM
Originally Posted by scuba
neat.... cant do that to mine... anyone with tips on how to mount to stock bumper without it shaking while offroad?
Old 12-11-2008, 02:55 PM
pray4surf's Avatar
Start with the cutting portion of the Satoshi Grill mod...
Now you can recess the lights into the grill
Side view - PS pic taken before aiming lights
Just rattlecan the exposed areas flat black...
Four holes = four lights
Of course, I've since upgraded to an aftermarket bumper and carried the light placement
Spraypainted the covers
PS - the stock bumper is available - Local (SoCal) pickup only
Any light mounted to the stock bumper (w/o add'l reinforcement) is going to shake...
yourrealdad
7
07-21-2015 08:53 AM
Luke
07-14-2002 02:01 PM
Luke
07-08-2002 04:22 PM
Corey
06-25-2002 08:39 PM
Quick Reply: Do Hella 500's on the front bumper affect engine temps + mileage?
