Diesel?
Old Jul 26, 2004 | 01:20 PM
Diesel?
as some of you know the 22r-e broke something, sounds like kids and hammers in it for like 3K miles, well she gave up the ghost and will not start. So time for a motor,
I would like to do a small diesel like they have in other placeses... any sugestion on where to find one or if anyone has done it,
Thanks
Shawn
Old Jul 28, 2004 | 06:58 AM
Shane's Avatar
Moved out to the general forum, I think you'll have a better chance of getting a response there.
Old Aug 13, 2004 | 10:37 PM
where you from KERR? there is an 84 toyota 4x4 with a 2.8L toyota turbo deisel sitting here in town. Don't know what the guy wants for the truck. But it's been rolled, so I'd imagine he'd sell it a little cheap. I'm thinking bout buying the truck and swapping cabs on it. but money is a little tight right now.
Old Aug 13, 2004 | 10:40 PM
914runner's Avatar
Its rare but there are a few DOT legal early toy pick-ups with diesels here.
Check out this site it has alot of info: www.brian894x4.com and this one too www.clean4x4.com
Old Aug 16, 2004 | 05:43 AM
Im in bristol Va, I wounder what all i would have to change to put a diesel in the truck. If you get time check it out.
Shawn_K_Kerr@yahoo.com
Old Aug 16, 2004 | 12:43 PM
kyle_22r's Avatar
i *think* the 3L(2.8L) and 5L(3.0l) diesels may bolt up, but i know for sure that the 2L will bolt directly to your engine mounts and to a w56 tranny with the diesel bellhousing. basically you only need to wire the fuel pump and starter to get it running, but it's a good idea to hook up the glow plug harness if you live in a cooler area
Old Aug 17, 2004 | 05:23 AM
cool, i just need to find a diesel now
Old Aug 17, 2004 | 06:28 AM
Ever think of using a Mazda rotary engine? Those things are light as hell. Plus you can make them really crank out some power. I've talked to a few people that use them in tube buggies. And they claim to be getting around 300 hp. at 10,000 rpms. I've never weighed one. But they are as light as an old VW beetle engine. Maybee around 200 lbs.
Old Aug 17, 2004 | 09:07 AM
no never thought of that, im to worried about the weight, i locked up 22re, just thought a diesel would be cool. but if its a lot more than the 22Re rebuild kit ill just do that. this truck is just a beater.
Old Aug 17, 2004 | 01:39 PM
kyle_22r's Avatar
the problem with mazda rotaries is that they have no torque at all, which isn't good in a typical 4x4. good sand rail engine, bad truck engine
Old Aug 17, 2004 | 05:12 PM
Kyle, I do agree with the lack of torque that the rotary engine has. But you can kinda cheat a little by using lower gears. the buggies I mentioned earlier run 404 portal axles under them. So, I'd imagine that they are pretty low geared. Those buggies work pretty darn well. I've seen them climb 6-7 foot ledges without even spinning a tire.
presto30
Engine Swaps
Dec 10, 2015 12:01 PM
an1mal_69
Sep 8, 2015 09:40 AM
seab1209
Sep 3, 2015 05:41 PM
