| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
CV removal, need help!
#2 (permalink) |
Hit the axle end with a rubber mallet or 2x4! It will knock loose!
Once it slides out of the spindle, you can pop the CV out of the diff with a by prying it out with a flat head or something similar.
__________________
BajaRunner
1996 4x4 3.4L SR5 4Runner 6" IFS lift * Front: TRD Coils/Bilstein 5125 * Rear: FJ80 Shocks/Coils * ARB Tacoma bumper * 35" MTR's and E-locked! Last edited by BajaRunner; 11-22-2009 at 03:05 PM. |
#3 (permalink) |
It it, with a hammer or somthing, its not pressed in or anything, should come out with a good knock.
Then pry put the shaft from the diff, sometimes crawling to the opposite side, and hitting the flange from behind is the best way to get it out. |
#4 (permalink) |
Thank you! i wasn't sure if it just knocked out or not, I didn't want to go hitting it in case I was missing something!
#5 (permalink) |
x3 on the hammer. it took at real beating to get mine off. ha
__________________
My Build Thread |
#6 (permalink) |
Pry bar is a must to get it out of the diff, or something that can be wedged between the axle tulip and the diff. I would put the nut on the end of the axle shaft, just a few turns, so that you don't ruin the threads with bad aim.
__________________
Rob 1999 4Runner Limited 4x4, retrofitted e-locker/ ARB front locker with 4.88 Precision Gears, Tundra/LC lift, 2" 4Crawler BL, Nitto Mud Grappler 35's on 16x8, Marlin sliders, TJM T-15, Warn M8000 w/ synthetic line, Mad Mike's custom rear Bumper, deckplate and ISR mods, Vortex Muffler, custom made tube doors pictures here I support Banned Neliconcept |
#7 (permalink) | |
Quote:
#8 (permalink) |
I just use a rubber mallet and whack it like I was hitting my driver down a wide fairway that would accompany my 50 yard hook
__________________
BajaRunner
1996 4x4 3.4L SR5 4Runner 6" IFS lift * Front: TRD Coils/Bilstein 5125 * Rear: FJ80 Shocks/Coils * ARB Tacoma bumper * 35" MTR's and E-locked! |
#9 (permalink) |
even like a brass punch or hammer works good
__________________
1998 4runner, SR5 5speed V6, trail gear sliders |
#11 (permalink) |
cv removal
hey there....
well the best tool to remove the axle from the hub is using a three jaw puller to equally apply pressure all the way around....using a hammer will risk damaging the threads in turn wouldn't be able to put the nut back on.... then your screwed causing more work for yourself....or money...... |
#12 (permalink) |
they make brass hammers theyre great
__________________
#13 (permalink) |
Just to add - they do make hard plastic/rubber dead blow mallets that work great for whacking things where you do not want the harm the metal. I have had mone for over 10 year and use it all the time.
__________________
'99 SR5 Sport - Desert Dune: AirRaid MIT, OEM Air Filter, Toyo 265/75/16 ATs, Deckplate, PP Springs and Bilsteins, Cheapo nerf bars, Injector replacement impending |
#14 (permalink) |
Yeah I said that twice.
![]() Anything brass, plastic, raw hide, wooden, rubber or what have you mallet will work. I really think its a waste of time to try a gear puller on something that isn't a tapered fit or pressed in.
__________________
BajaRunner
#15 (permalink) |
Just whack the end of it with a rubber mallet, and then use a prybar to pop the cv out.
I've done this a lot.
__________________
97 4runner, 2.7 5speed 4wd, 5.29, 33 horns armor locked lifted heavy SOB broken front and rear swaybars My Profile.. |
#16 (permalink) |
AND THEN add some anti-seize to the hub side splines so you dont have that problem next time....incase you need to change it on the trail or......
__________________
Yes, I said "country." America really is a nation, but you couldn't convince those who lead the Democratic and Republican Parties of that. Both parties now see America as nothing more than an economy, a marketplace, and not a sovereign nation. They don't see you and me as citizens of this great nation; they see us as units of labor, consumers and taxpayers. Yes, I am here to collect my 238$ worth of stock from AIG. "What do you mean a free market economy doesnt apply to the rich?" |
| Tags |
| 4runner, add, cv, hub, removal, sr5 |
