Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Couple of Questions!?!?
Hi all.
Ok first off I want you all to check my math on somehting I have a 1990 runner with a man tany. 1. Math part of the text! 4" sup lift + 2" body lift+5.29 gears=35" tires 2. tech part of the test. My steering box is leaking and I have two choices replace the box (+/- $345) or get a seal kit (+/- $150) with cost aside which would be better. other then a bad seal there is nothing worng with my steering box. and eather way I have to remove the steering box. has anyone don't this before? This is the first time I have had the option to just rebiuld the seal. Which one would you'all go for! Thanks for the help guys!!! Matthew :alien: |
| Sponsored Links |
#2 (permalink) |
Sorry to leave this unanswered so long. 35s will fit with the lift mentioned, you will need 5.29 gears to turn them.
I would deffinatly rebuild the steering box instead of buying one off the shelf. If you have the time and ability to keep that $345 in your pocket. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Couple of questions... | 4Runner 4Play | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 08-09-2004 03:16 PM |
| Just a couple of questions | Ryan Shear | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 07-20-2004 09:19 AM |
| a couple questions | goatboy22382 | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 06-28-2004 01:15 PM |
| A Couple Questions | J Rock | 95.5-2004 Tacomas & 96-2002 4Runners | 17 | 10-06-2003 06:35 AM |
| a couple of questions | nolongeraneqaddict | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 07-04-2003 11:20 PM |
