compression problems
Old Jun 21, 2004 | 08:53 AM
suthrn98@aol.com's Avatar
I just rebuilt my engine in my 94 4x4. Its a 22re and I put in new pistons and everything. it will only crank up after trying forever, once running it runs fine, but when I shut it off, it wont crank back up. Adjust timing and play with it a little while and it will finally start again. Put a compression tester on it and only got 25 on 3 and 50 on the last one. suppesed to be around 175. Does anyone know what my problem could be?
Old Jun 21, 2004 | 09:03 AM
AgRunner06's Avatar
Maybe you didn't adjust the valves correctly. If I remember correctly from reading other's threads here, there is a cold adjustment and then you have to readjust when they are hot.
You also could have gotten a bad rebuild on the head and the valves aren't seating correctly.
That's my guesses.
Good Luck
Old Jun 21, 2004 | 09:14 AM
I adjusted the valves and all that good stuff. The valves not seating could be a problem, but on all 4 cylinders? Someone told my dad that if the rings were in upside down, it would cause a loss in comp, but I also know from experience that if the timing is off, it will cause all the valves to still be open on the compression stroke.
Old Jun 21, 2004 | 09:31 AM
radrex's Avatar
Squirt some oil in the cylinders and see what the compression comes to..
If your compression is that bad - and the valves are adjusted properly, you might as well start tearing it back down and identify the culprit.
Old Jun 22, 2004 | 03:08 AM
bump,
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
the1998sr5
27
Nov 17, 2015 09:30 AM
RatOmeter
Oct 22, 2015 03:17 PM
thefishguy77
Jul 30, 2015 10:59 AM
