clutch replacement
Old 05-11-2004, 10:10 PM
Godzilla's Avatar
clutch replacement
this is my first manual vehicle (92 4runner 5spd)and am wondering how do i know when the clutch is coming to an end. i got the vehicle about 4mnths ago and have put on about 8000km.
Old 05-11-2004, 10:20 PM
amusement's Avatar
Godzilla you will notice feel the clutch sliping when you first engage the cluth or going up hills. Hills and starting are the most stress full on the clutch. Towing is also stressful. It's really not about mileage but some clutches wear as fast as 68000 kilometers. My '95 started to slip about 120000 km. Cost of parts is under CAN$220. Labor is more expensive about CAN$80 per hour for a certified mechanic. So the whole thing could be CAN$400-500. Don't forget to change your slave cylinder when the clutch is changed.
good luck
Old 05-12-2004, 12:44 AM
Mystickal's Avatar
An old, tried, and true test:
Place shifter in neutral.
Apply parking brake.
Depress clutch pedal.
Shift into first gear.
Slowly release clutch (note that parking brake is still applied).
If the vehicle stalls, your clutch is engaging the flywheel enough.
If the vehicle doesn't stall, the clutch is slipping and you need to replace it.
If you want to know if the end is near, look for things such as RPMs moving up while you press down on the gas, but speed staying constant. But, for the most part, as long as it passes the above test you're ok.
~Bill
Old 05-12-2004, 08:13 PM
Godzilla's Avatar
thanks for the replys, seems like my clutch is still a.o.k
smthwsn357
12-04-2023 02:08 AM
the1998sr5
15
07-14-2020 08:35 PM
mskalmus
05-28-2017 07:51 AM
09-04-2015 09:27 AM
Kalihi,HI
07-09-2015 04:29 PM
Quick Reply: clutch replacement
