YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 03-15-2004, 10:27 AM   #1 (permalink)
CMD93's Avatar
Clutch fluid ?'s
I've got a quick question.
This weekend I noticed that my clutch fluid was right below the low mark on the resivor(sp?). Is all I have to do is just fill it up to the full mark? Is it not tied into the brake fluid at all?
Thanks,
Chris
__________________
1993 4runner V6,SR5, 5-Speed, 4WD, Amsoil, Downey HD's.
1982 FJ60 Landcruiser, 120K, totally stock....work in progress
CMD93 is offline
Sponsored Links
To remove this ad, register today!
Old 03-15-2004, 10:42 AM   #2 (permalink)
85runner's Avatar
Yes, fill it. Even though you put brake fluid in it - it is not tied to the brakes.
Since it is low, you may want to get under the dash and make sure it isn't leaking into the cab.
__________________
Korrupt Krawlers
CrawlinAZ.com - Arizona Runs
85runner is offline
Old 03-15-2004, 03:03 PM   #3 (permalink)
CMD93's Avatar
85Runner,
I don't think that it is leaking under the dash, I hope that I would have noticed that, but I will surely take a look. I was just down there the other day organizing some of my wires left over from the Hella light install. Thanks for the tip.
I have no idea how long it has been low, I bought the truck used and I guess I have overlooked it. I thought that my mechanic would have filled it up during the past oil changes or at least notified my as to whether that has been a reoccuring thing. Oh well I guess I just keep an eye on the level.
If it is not leaking under the dash and the level continues to decrease where would it be going and what actions would I need to take next? What could be wrong? Any ideas?
Thanks,
Chris
__________________
CMD93 is offline
Old 03-15-2004, 03:15 PM   #4 (permalink)
85runner's Avatar
You would look at the slave cylinder next. Its what pushes the clutch actuator on the transmission. Make sure you aren't leaking from there.
__________________
Korrupt Krawlers
85runner is offline
Old 03-15-2004, 03:18 PM   #5 (permalink)
CMD93's Avatar
Cool thanks,
I'll check in my Chilton's on the location.
Chris
__________________
CMD93 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Leaking clutch fluid G's 84 Runner 84-85 Trucks & 4Runners 2 07-13-2007 06:50 AM
Clutch leak/Dark clutch fluid geoduke 86-95 Trucks & 4Runners 2 04-04-2006 07:51 PM
97 runner - clutch fluid replacement? denverbikeguy 95.5-2004 Tacomas & 96-2002 4Runners 4 07-15-2004 08:40 PM
Is it neccessary to flush clutch fluid? ByThaBay 95.5-2004 Tacomas & 96-2002 4Runners 4 09-26-2003 02:42 PM
Clutch fluid... rpeAMP 95.5-2004 Tacomas & 96-2002 4Runners 5 08-21-2003 08:26 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
