Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Clutch fluid...
I think it's about time to flush out the clutch fluid, and was curious if any of you have done this yourself or can point me to a writeup that I can take a look at.
Thanks in advance.
__________________
Preston Edwards 1992 4Runner SR5 V6 4WD (5 Spd.) 246,000 miles & counting 2" Downey coils, 32x11.5x15 BFG A/Ts, Rockcrawler Series 51 wheels, Magnaflow exhaust, Yakima roof rack, ARB bull bar, SAW Torsion bars, (4) PIAA 520s, Cobra 18 WX ST II CB w/ Firestik antenna, hp iPaq GPS 2007 Toyota Tacoma TRD Sport 4WD (5 Spd. Auto) 400 miles & counting |
| Sponsored Links |
#2 (permalink) |
By clutch fluid I guess you are referring to the hydraulic fluid for the actuator. I've flushed mine three times in the last year. Once when I blew the hydraulic line last year, once when I blew the seal on the actuator last month, and last week when I replaced the clutch in the truck. All three were not by my choice. If it's the same set up on my truck, just open the bleeder screw on the actuator and open the top of the fluid resevoir. Once it's empty close off the bleeder screw, refill the resevoir, and bleed the system just like you would for the brakes. I'm not sure why you would have to flush it unless you got water in the system and the pedal is spongy, but that's the procedure.
__________________
____________________ Greg 93 4x4 pickup |
#3 (permalink) |
MN,
Is that the only way (or correct way) to do it? Is it possible to take a siphon hose (or siphon pump) and extract it that way? And then just refill? Bob |
#4 (permalink) |
Thanks for the info!
The main reason I want to do it is because I don't know when the last time it was done. I haven't done it since I purchased the truck last year. Where's the drain plug located approximately?
__________________
#5 (permalink) | |
Quote:
There isn't really a drain plug, it's a bleeder screw same as you have on the brakes. If you look under the truck, there should be a small cast metal cylinder bolted to the bell housing, with a pin coming out one end that actuates the arm that sticks out of the transmission. The bleeder screw is on the side of the cylinder. You probably don't have to flush the system unless you are having problems with the clutch. Check the fluid in the resevoir to see that it is light yellow in color like clean brake fluid (which is what it is) and make sure the clutch is operating correctly and just leave it alone until you have to replace the clutch, which will be sooner than you want if you are wheelin your truck at all.
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Leaking clutch fluid | G's 84 Runner | 84-85 Trucks & 4Runners | 2 | 07-13-2007 06:50 AM |
| Clutch leak/Dark clutch fluid | geoduke | 86-95 Trucks & 4Runners | 2 | 04-04-2006 07:51 PM |
| 97 runner - clutch fluid replacement? | denverbikeguy | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 07-15-2004 08:40 PM |
| Clutch fluid ?'s | CMD93 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 03-15-2004 03:18 PM |
| Is it neccessary to flush clutch fluid? | ByThaBay | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 09-26-2003 02:42 PM |
