clunk in reverse
clunk in reverse
so today i was backin out of my driveway to discovery that when i hit my bakes while going on reverse my truck started makin a gawdawfull clunkin and bangin sound, and suggestions of what i should check to see what it is?
lena
lena
Is it one loud click noise or is it a continuous noise? Mine makes a loud click in reverse when I hit my brakes, and it seems to happen to others too with an auto tranny.
Maybe this will help
https://www.yotatech.com/forums/f2/s...everse-233787/
Have someone crawl under there and look for something obvious.
Where is the clunking appear to coming from? The rear?
If so, maybe a broken spring leaf, loose shock, loose u-bolts, loose spare tire.
Maybe drive-shaft contacting gas-tank skid plate (happened to me once).
I would also just look at your universal joints also. Make sure they aren't busted apart anywhere. Start with the visible easy stuff first before you start opening or removing things.
yeah i know dc, the clunking doesnt come from the rear, it just does it when im in reverse, regardless i know i need a new brake caliper because the threading where one of the bolts goes in on it is stripped, so everytime i hit the brakes the thing is movin
Odin
09-26-2015 06:56 PM
May-39
09-06-2015 01:05 PM
