Clicking Radio-revived
So, you've read my tribulations with my recent spark-plug ordeal (PO overtorqued, sparkplug flew out, blah, blah, blah.)
Additionally, I posted some time ago about my radio and how it would "click" on FM frequencies during pedal-off cruising or idling, but not accelerating.
I just put the two together. The spark-plug must have been loose since the day I got the vehicle, as the radio click was there all along. Now that the spark-plug is fixed and melted coil replaced, the radio is clear.
So, if you've got a radio "click" that seems to follow engine RPM, check your ignition coils, and your spark plugs. You'll wish you had.
uberhahn
uberhahn
I just started to notice that in my rig today. I installed an xm radio w/ my alpine cd player. I bought an AI-net adapter 3 in 1(3.5mm jack,av,nano plug-in) I plugged the 3.5mm jack directly to the xm radio and notice a high pitch when I would set the volume high. I turned OFF the xm radio and the pitch was still there, it would get higher as I accelerated. My doesn't click like yours did, makes more of a whining noise as I accelerate, I'm thinking a ground loop would clear this up. What to you guys think??
Location: Far western Kentucky (transplanted from central PA)
Whoreunner, that almost sounds like an alternator whine to me. There are filter kits out there that are fairly simple to install.
zombie_barbarossa
10-02-2015 10:54 PM
PureTacoma_Tundra
PureTacoma_Tundra
09-24-2015 12:14 PM
