Chirping noise - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-01-2002, 04:42 AM   #1 (permalink)
Question Chirping noise
My 4Runner makes a strange noise that seems to be coming from the drivetrain. It is a chirping sound, sort of like a cricket. It only occurs when decelerating. Giving it a little gas makes the sound go away. It seems to go away below 25mph. It is not brake related. It is there whether or not the brake is applied. It is most noticable when coasting down a hill at 30-50 miles per hour. Coasting in neutral does not change the sound either. Does anyone have an idea about what this could be?
The truck is a 99 4Runner, Highlander, V6 automatic. Thanks.
cheapo is offline
Old 10-01-2002, 11:59 PM   #2 (permalink)
Staff
Yoda's Avatar
grease the u joints and see if it goes away. Also check them for play while down there.
__________________
David
TLCA 14788
71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap.
76 Landcruiser FJ-40 project/parts (haven't decided)
Yoda is offline
Old 10-02-2002, 05:10 AM   #3 (permalink)
Exclamation Chirping Noise!
I had the EXACT SAME problem on my 1999 Toyota PreRunner TRD OffRoad AUTO, V6. Kept taking it back to the dealer. Never would nake that noise when I took it in. I finally drove around with a tape recorder. and FINALLY go it on tape... Well, THEN it would make the noise with the toyota tech's in the truck.
Anyway.. the culprit was a dry rear diff yolk. It was not the U-Bolts. The rear diff's front yolk did not have enough grease or something. They removed that, lubed it up and it has been silent ever since!
Hope this helps!
5VZFE
__________________
"So, I drank the juice, said the words and here I am"
5VZFE is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
TSB EG012-03- Drive Belt Squealing and Chirping Noise Bob_98SR5 03+ 4Runner/GX470, & 05+ Tacomas 1 03-23-2006 10:15 PM
02 Sienna whining/chirping noise under hood momof3cuties Maintenance & Repair Archives 6 03-14-2005 12:25 PM
"chirping" noise at low rpm's Johnboy 95.5-2004 Tacomas & 96-2002 4Runners 7 02-14-2005 05:10 PM
need help with a chirping noise - 97 4runner sage 95.5-2004 Tacomas & 96-2002 4Runners 9 05-30-2004 02:36 PM
Loud squeaking/chirping noise...help?! Pretacopower 95.5-2004 Tacomas & 96-2002 4Runners 2 11-14-2003 04:52 AM
2009 InternetBrands, Inc.
