checking for exhaust leaks - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-30-2004, 09:22 AM   #1 (permalink)
evilcow's Avatar
Whats the best way to check for exhaust leaks? I'm pretty sure I have a exhaust leak. just dont know where,
evilcow is offline
Old 09-30-2004, 09:30 AM   #2 (permalink)
SloPoke's Avatar
Send a message via AIM to SloPoke Send a message via MSN to SloPoke Send a message via Yahoo to SloPoke
Visually.
Get under there and check for the leak. It should have a small amount of soot/carbon showing through the leak. At least, when mine springs a leak, that's how I track it. Either that or do it with the engine running and feel around (careful to not burn or affixiate yourself) for hot exhaust coming from anywhere but the end terminataion opening in your exhaust. If you got a buddy to help, he can put his hand over the exhaust pipe to limit the amount coming out and try to force it through the leak maybe making it easier to track if there isn't any soot/carbon showing yet.
Good luck!
__________________
Yoats & stuff
SloPoke is offline
Old 10-01-2004, 07:43 PM   #3 (permalink)
nunsa's Avatar
Quote:
Slopoke got it right, but you can also get yourself a bottle of soapy water and start spraying, you'll find it!
__________________
The Master Toyota Tech,
2003 Toyota Tacoma xtra-cab, 3.4 V6, 5speed,4x4, TRD w/OffRoad Package.
"Expert on the 3.0 Engine!"
Disclaimer: As a former TOYOTA TECHNICIAN I authorize this post/reply
US MARINE*** SEMPER FI
nunsa is offline
Old 10-03-2004, 06:24 PM   #4 (permalink)
evilcow's Avatar
Found it. It was the exhaust manifold. Looks like the gasket is blown by the #4 cylinder. Is changing the gasket a easy fix. Any tips?
Thanks
evilcow is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Checking for Vacuum leaks/carb clearner rdharper 86-95 Trucks & 4Runners 4 11-11-2006 09:03 PM
New 4runner owner: Rust, Leaks, Exhaust and More! krew 86-95 Trucks & 4Runners 1 10-05-2006 02:32 PM
too lean CEL, what's a good way to check for exhaust leaks and vacuum? firedog 95.5-2004 Tacomas & 96-2002 4Runners 0 12-11-2004 07:45 PM
Exhaust leaks midiwall 95.5-2004 Tacomas & 96-2002 4Runners 6 08-19-2004 05:14 PM
97 4Runner rear axle leaks - HELP an Aussie !! R cannot stop leaks !!! beddo 95.5-2004 Tacomas & 96-2002 4Runners 8 08-06-2004 05:48 PM
2009 InternetBrands, Inc.
