| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
check engine light + engine miss
#2 (permalink) |
Well, if it sounds like a miss and there is a MIL on, then chances are you got a miss. If a cylinder does not fire, it can set a lean(because of the o2 not burning) code. The usual spark plug/wire ect. should be checked out if the code and miss are verified.
#3 (permalink) |
yep we replaced the plugs and its fine
![]() thanks kelly |
#4 (permalink) |
Kelly,
About a month ago, i installed new spark plugs and wires. After installing, I had a random "skip"...it was as if the engine was missing here and there. Since I have a stick, I could feel the "pulse" in the shifter. Turns out the problem was with one of the brand new spark plugs. One of the electrodes was closer than the other. I replaced it w/ the old plug until I could buy a new, replacement plug. Runs like a champ now. If you've recently replaced all your plugs, I would suggest you take a look at each and every one again. If that isn't it, I believe ol' Mertztr had a problem with this light that required him to replace his O2 sensor. A DIY job. Bob Last edited by Bob_98SR5; 11-03-2003 at 07:16 PM. |
#5 (permalink) |
yep its fine.. cyl #2 wasnt firing but replaced all the plugs and wires.. and the lgiht went away after a min
good to go ![]() kelly |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Engine swap/check engine light? | spacoli | 86-95 Trucks & 4Runners | 1 | 11-29-2006 07:39 PM |
| Engine Miss/Check engine light - Possibly TPS? | Extremesolo | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 09-17-2005 09:58 PM |
| Check engine light is on. What to do now? | cccp | 95.5-2004 Tacomas & 96-2002 4Runners | 22 | 03-30-2005 05:50 PM |
| Check Engine Light | Smarly | 95.5-2004 Tacomas & 96-2002 4Runners | 26 | 02-08-2005 09:08 AM |
| Check engine light on | Juggalo | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 10-24-2003 11:06 AM |
