Cheap bastards idiot guide for fixing fast blinkers after LED swap
Old Mar 9, 2006 | 04:27 AM
SloPoke's Avatar
My wheelin partner installed some LED's and didn't like the fast blinking or the resistor fix so......this is what he did. Thought I'd share with yaul.
The relay that needs to be modified is well hidden. You will have to take down the lower part of the dash and remove the two bolts n the picture below:
Once you have those removed you can wiggle the box down. The arrow points to where the relay should be, the relay had already been taken it out when the picture was taken.
Here is what the unit looks like:
He is lazy and rather than scraping the solder off that terminal he just drilled out the red spot in the pic below. This is the "Lamp Failure Detection" pin according to this link, page 3. http://www.atmel.com/dyn/resources/...nts/doc4727.pdf
After you drill it out, just put everything back together and you’re done.
FWIW: the truck this was done on is a 1999 TRD model, and the label on the top of the chip is U643B.
Hopes this helps. Easy mod and only took about 10mins once he found the relay.
If you have ?'s you can mail him direct at sloth@r65.org
Old Mar 9, 2006 | 05:19 AM
Tofer's Avatar
Sponsor
sweet! i'll have to keep this in mind.
Old Mar 9, 2006 | 06:04 AM
MTL_4runner's Avatar
Good work on solving that one!
You can also just use an exacto knife to cut the circuit board trace.
Old Mar 9, 2006 | 10:25 AM
BruceTS's Avatar
I like this mod, I tried to get an aftermarket soildstate one to work with no avail, I guess I'll be installing all my LED's now!
Old Mar 13, 2006 | 12:56 PM
BruceTS's Avatar
For those with 4Runners, you probably have the Denso flasher, this will need to be replaced with the Tridon unit part # EP-35 sold in most automotive outlets. I got one at Pepboys for $8.95, did the modification and it works great! Here's another write-up I found
Old Mar 15, 2006 | 05:33 PM
BruceTS's Avatar
I installed the LED's in the rear and for those who are afraid tht they aren't bright enough in the daylight, they are. what's really cool is the back-up light now produces a true white light and not the yellowish glow the stock bulb puts out. I still need to install them in the front, but that's gonna take a bit more work since I'll be replacing the entire turn signal assy.
Old Mar 16, 2006 | 06:55 PM
SloPoke's Avatar
Why do the Runners have to replace it with the Tridon unit?
Old Mar 16, 2006 | 06:59 PM
SloPoke's Avatar
That's what we did first but it was a PITA so we just drilled it out and viola...done deal.
Old Mar 16, 2006 | 09:12 PM
BruceTS's Avatar
Taco's are assembled in the USA and 4Runner are assembled in Japan, hence the difference in parts......
Old Mar 17, 2006 | 06:34 AM
SloPoke's Avatar
So, is the Runners flasher is not take apartable? Should have the same failure check circuit shouldn't it? or are there no circuit maps available for the Japaneses blinker boxes?
Thanks
Old Mar 17, 2006 | 03:35 PM
BruceTS's Avatar
Thanks
Actually they are electronic, and the circuit traces from the IC are similar, but cutting the trace to pin 7 just kills the flasher, I tried every combination to see if I could get it to work with no avail. Far easier to go down to a local discount auto parts store and buy a replacement one.
The next modification I plan to do to the Tridon flasher unit, is install a variable resistor to control the rate which it flashes, it goes a bit too fast for what I need it to do.
Old Mar 19, 2006 | 05:15 PM
BruceTS's Avatar
Ok, I played around with the flasher unit today and finally got the rate set exactly where I need it, for my new front sequential LED turn signals to operate properly. Next step is to modify the front bumper to install them and add in fog lights as well.
Old Mar 21, 2006 | 02:12 PM
BruceTS's Avatar
I've got the BLING!!!!!
That's right my new front turn signals are now installed and working perfectly! I'll post some picture later on tonite when it gets dark to get a good shot of them in action.....
Old Mar 28, 2006 | 06:18 PM
elnip's Avatar
Nice Bruce! The link in the first post is not working anymore so did anybody copy the pages?
Old Mar 29, 2006 | 05:13 AM
BruceTS's Avatar
The link to the .pdf file won't work, but if you go to the site you can do a search and get the pages.......
Old Mar 29, 2006 | 05:18 AM
elnip's Avatar
Roger that. I was in a hurry last night and didn't feel like digging!
Old Jun 20, 2006 | 03:09 PM
jbd202's Avatar
Hey brucets what type of LED bulbs are you running and where did you get them. I am looking at getting some but I don't want to waste my money on something that is no good.
Old Jun 20, 2006 | 04:29 PM
runnerSR5's Avatar
Is there a tech write up for LED turn signals on 4runners?
Old Jun 20, 2006 | 04:56 PM
midiwall's Avatar
The post at the top of this thread explains how to deal with the speed issue if you want to mod your current flasher module.
Or, head here and buy a replacement module:
http://autolumination.com/equalizers.htm
Or, in the 5th message of this thread, BruceTS points to another writeup of the mod.
Old Jun 20, 2006 | 09:06 PM
BruceTS's Avatar
rear turn signals
Quantity: 2
Product: 7440-15 LED bulb $ 6.99 (each)
Options: Amber
back-up
Quantity: 2
Options: White +$2.00
brake
Quantity: 2
Product: 7443-15 LED bulb $ 6.99 (each)
Options: Red
front markers (194 type)
Quantity: 2
Product: WLED 5-LED Wide Angle LED bulb $ 2.99 (each)
Options: Amber
license plate(194 type)
Quantity: 1
Product: WLED 6-LED bulb $ 2.79 (each)
Options: White +$0.95
not sure what stock front turn signals are since I didn't need them, but this is where I purchased them from... http://www.superbrightleds.com
if you do a search on this board there are many threads about this subject....
A 4Runner, it is similar to the Taco... the flasher unit is located on top of the fuse box.....
