Changed spark plugs, now i have a high idle
Old 05-07-2010, 06:51 PM
hungryeddy's Avatar
so today i replaced the oil, spark plugs, air filter, and oil filter... before my idle was at about 700 and now its at about 1500... any ideas?
i don't know if this matters, but i went from NGK plugs to bosch +4
HELP!
Old 05-07-2010, 07:08 PM
kball's Avatar
You mean after it's warmed up it still idles that high?
Maybe you have a vacuum hose not attached..?
Old 05-07-2010, 07:13 PM
GranVille-4crawler's Avatar
Turn your idle down lol. Could be that with your recent tune up your getting more spark =ing more rpms...?
Old 05-07-2010, 07:19 PM
874runnersr5's Avatar
Yeah, could be that your engine is running correctly so now you gotta turn down your idle.
Old 05-07-2010, 09:05 PM
hungryeddy's Avatar
can someone tell me how to do that? .......................... ROOKIE STATUS
pictures would be nice... if possible
Old 05-07-2010, 09:36 PM
Kiroshu's Avatar
Ok Year/make/model? Make sure all vac lines if any where disconnected are re-connected. NGK is better anf recommended for toyotas... bosch was not the best way to go should have kept NGK.... But its your truck.
Old 05-07-2010, 09:45 PM
hungryeddy's Avatar
I have a 97 4runner with the 6cyl engine
Old 05-07-2010, 09:55 PM
Kiroshu's Avatar
Have you let it warm-up to see what its idle was then? Or is that what it is at operating temp? Theres a vac leak somwhere most likely. NOTE: "Never adjust the idle on a fuel injected engine." Or you will never get it back perfect. If its not idling properly then theres something wrong. Check vac leaks. Just back track and look around. Plug a vac ling into a wrong spot where another vac line is supose to go? Mixed up. Does it run rough upon this idle? Intake tube tight? Mass air flow plugged in?
Old 05-07-2010, 10:17 PM
hungryeddy's Avatar
Its definately not a temp issue... I warmed it up for quite a bit and took about a 20 trip. I will check the lines but I highly doubt it since that was my first guess and I've checked them already...
Old 03-02-2012, 08:07 AM
Gavin S.'s Avatar
Sorry to all for bumping a necro-thread, but I am having this exact same issue after a plug change on my 96 V6 4Runner. I've checked my hoses so I'm stumped. Thanks.
bryan34w
07-06-2015 05:53 PM
Jnkml
07-06-2015 01:20 PM
karbin
07-05-2015 11:37 PM
elwood73
07-05-2015 07:07 AM
Quick Reply: Changed spark plugs, now i have a high idle
