CEL and VSC lights on !
Old 11-12-2009, 12:22 PM
xcmountain80's Avatar
I got a pocket code reader and this is what I have line by line......
P300
P303
Mil On
Monitrs
2 Inc
Catalyst
Evap
5 Ready
Misfires
Fuel
Comp
02 Sensr
02 Htr
I think one of my coil packs or power packs (whatever they are called) are going as the truck runs like crap when cold. If I have to guess it would be the pack closest to the firewall. I have a spare packs and will replace all 3 tomorrow, I also have another 02 sensor assuming they are the same for the front on a 02 Tacoma. The rear O2 sensor might be going but it could also be the cat, I have a URD O2 sim on that so the #'s down stream are fixed. I assume if a coil pack was bad the mix could be wrong and then set the front O2 off, but gimme a hand please.
A
Old 11-12-2009, 07:36 PM
So no one had any insight on this?
A
Old 11-14-2009, 06:08 AM
I replaced Cylinder #2's coild with another one and still get weird readings on the OBII reader, though check engine lights go figure.
A
Old 11-14-2009, 12:44 PM
Aww SOB now it's cylinder #4, I went and bought new plugs and wire JIC this ends up being simple and cheap.
A
Old 11-14-2009, 01:10 PM
Thelast83inNJ's Avatar
PO300 is ramdon misfire. PO303 is cyl#3. P304 is cyl#4 etc etc. Plugs first, wires second or put your timing light on each wire it and see it flash tells you wire and/or coil pack ok. Cat efficiency code is P0420,most time cat is bad not O2. Your ready monitors say that all have run ok including heated o2s
Old 11-14-2009, 03:19 PM
Awesome info had I read my manual that came with the code reader it might have told me that. I bought new plugs, wires and I Have some pre-owned coil packs. Will transfer tonight..............
A
Old 11-15-2009, 03:35 PM
So I might have found the problem..................
A
Old 11-15-2009, 08:47 PM
Can Anyone see the problem?
Anyone?
raptor510
02-17-2017 07:11 AM
AkitaDog
09-01-2015 08:05 AM
256mbaker
07-31-2015 06:45 PM
nonstop
07-24-2015 06:29 PM
Sandman
07-14-2015 12:36 PM
Quick Reply: CEL and VSC lights on !
