CEL Code: P0141
Old Mar 4, 2009 | 11:00 AM
tiredandwired's Avatar
CEL Code: P0141
Hi-
CEL P0141-read Bank 1 Sensor 2 malfunctioning circuit heater...( or something close to that). Is this the rear 02 sensor and would my truck start/idle rough because of it? The 02 sensor before the Cat and the cat are new.
I have a 95 Tacoma 4x4 AT 130,000 mi.
Thanks!
Old Mar 6, 2009 | 04:18 AM
Looking for some advice..
..before I buy a nonrefundable sensor
Old Mar 6, 2009 | 04:35 AM
BigBallsMcFalls's Avatar
buy the sensor
because that is what is broken
no one is answering because this subject has been discussed ad nauseam
Old Mar 6, 2009 | 04:42 AM
turyota90's Avatar
unplug the sensors. if it's a 4 wire sensor, there are 2 wires the same color(white usually). that's the heater wires. with a DVOM on continuity check the 2 wires on the sensor harness. if continuity, sensor is good. if no continuity, it's bad. always better to double check and make sure it's the sensor and not the truck
Old Mar 6, 2009 | 04:46 AM
Thanks for the replies. I searched both under the code and under O2 sensor and got back only a couple of hits.
Appreciate the response~
Old Mar 6, 2009 | 05:27 AM
don't bother testing it. 130,000 miles, the code is real. I will (poop) bricks if it isn't.
the sensors die between 100,000 and 150,000 miles amost always
Ronnyboy
Feb 11, 2016 05:57 PM
Sam hain
19
Sep 30, 2015 08:25 AM
charlie_fong
Sep 27, 2015 10:06 PM
Draven023
Sep 26, 2015 12:41 PM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
