CB Radio Install
You should easily be able to route the coax through on of the rubber grommets in the firewall. I got 0 gauge wire through it so anything can be done, I dont know what you would run that would be near as thick as my 0 gauge.
I routed mine passed the weather seal on the passenger side. My coax was already set, it wasn't one of those you solder the cap on when you're done with installation.
Towards the bottom of the passenger side on the Tacoma, there's a little crack in the door jamb that leads into the fender. It pinches the cable but I haven't had too many problems with it.
I'll check it out and see if its the same thing on my 3rd gen pickup. If not i might just get one that i have to solder or whatever.
#25
My cb power wire is linked into the ciggarette lighter power wire so that way it comes on with the car and wont drain the battery. The antenna wire is no prob, you can jam just about anything through the friewall ports, (the rubber holoe plugs with the wires going through them) Just slice a small slit int othe one you want to push it through (there is one on either side) and jam it through! then run it to wherever you want to mount the antenna. good luck!
#27
That's a FAT coax to jam through the grommet. I tried like crazy and wasn't successful when I tried.
#28
Sounds like an antenna problem to me???
I read that keying the mic without having the antenna properly hooked up risked frying the insides.
Unless maybe the power was hooked up wrong? Doesn't sound like you were using the mic when it started smoking.
Either way, sorry to hear about the loss of the CB - I hope you get the problem figured out
#29
#31
Well, I dunno - could it be anything else other than the antenna?
Anybody out there know? Maybe it was a faulty CB?
jasonty
41
12-23-2018 01:00 PM
FS[SouthEast]: 87 toyota pickup 4x4 22r
Yota.Jay
07-26-2015 05:50 PM
WTB[MidAtl]: WTB: 89-95 radio brackets/standard cab carpet 2wd
mtb_taco
07-15-2015 08:36 AM
