Can you identify these pads? (bww!)
Old 01-05-2004, 02:27 PM
Guest
4RUNR's Avatar
Metallic? Semi? Ceramic?
New? They are only 9.2mm thick from the plate backing.
Made in Canada? Any identifies if they are quality?
Old 01-05-2004, 03:24 PM
Unhappy99's Avatar
There should be a company name stamped into the back side of the backing plate. In any case, the FF pad code friction rating is desirable.
Old 01-05-2004, 05:51 PM
Firefyter-Emt's Avatar
I can not quite make out the picture.. Do you have something a little bigger so I can get a better look??
Old 01-06-2004, 10:04 PM
williemon's Avatar
You might try to see if a small magnet will stick to the friction material. I noticed that on a set of semi metalic that a vinyl magnet would stick whereas it would not to an organic friction material.
Old 01-07-2004, 05:53 AM
Guest
4RUNR's Avatar
Nope, no sticking. I'm pretty sure they are ceramics since they are very light, barely tan color.
I put them in already, had 8mm left on old ones, and these are much firmer so they must be ceramic.
Old 01-07-2004, 08:11 AM
MTL_4runner's Avatar
They are either organic or ceramic pads because even the semi-metalic you will see little shiny areas on the pads. My be would be ceramic as well since the little brown specs are not usually in a regular organic pad and those pads appear lighter in color than usual as well. Some manufacturers use different compounds so it is tough to tell for sure.
Old 01-07-2004, 03:08 PM
4Paws's Avatar
I think the picture is of the Mars Rover tire grooves.
Old 01-08-2004, 07:36 AM
mt_goat's Avatar
Never mind the pads what is that material they are sitting on?
Old 01-08-2004, 09:15 AM
Guest
4RUNR's Avatar
An orange goat that fetches me the wrenches of course
Old 01-08-2004, 12:56 PM
instntset's Avatar
Old 01-14-2004, 08:01 AM
Unhappy99's Avatar
Stumbled across the answer....TS C
Trustar ( a marketing conglomerate )
Cermamic ( what the C means )
Trustar is a marketing company and doesn't manufacture anything. They rebadge and distribute.
If I were to make a slightly educated guess, I'd say these were built by Bendix.
ladybugRC
458
08-21-2020 10:41 AM
user 82300
09-22-2015 07:00 AM
Bill854x4
09-20-2015 04:32 PM
sonorn67
09-19-2015 05:39 PM
user 82300
09-15-2015 05:49 AM
Quick Reply: Can you identify these pads? (bww!)
