can you cram 33x12.50 16 under a 3rd gen?
Old Oct 1, 2004 | 10:54 AM
Bigkahuna808's Avatar
I was wondering if I could cram thoes tires under my wheel wells. I curently have a 3 inch revtek up front and 3.5 downey HD in the rear. With a 2 inch body lift on the way from RB. The only problome/ question I got is I'm running a tottaly different rim size than everyone else's 16x7 . Its a 16x10 weld . Not to sure of the offset though. Right now without the body lift, Im fitting 265/70/16 on them untill the lift is done. All I really want to do is fill in the wheel well best I can without the risk of rubbing. Thanks for the input guys.
Old Oct 1, 2004 | 02:58 PM
Tacoma Dude's Avatar
I'd think you'd have to deflate them a bit...
I can barely fit my 265/70/16 spare with the Hidden Hitch I have.
When I put the 32" spare under there I'm going to deflate it a bit and make sure I have reliable on-board air.
Old Oct 1, 2004 | 03:11 PM
thanks,
But Im trying to see if it will actually fit the truck fenders itself.
Old Oct 1, 2004 | 03:44 PM
4RUNR's Avatar
Guest
TacomaDude you must be a CEO, giving a response after only reading the heading
Old Oct 1, 2004 | 04:15 PM
Nitro Hotpants's Avatar
the width on those rims are gonna kill ya. it could be hard to fit that wide of a wheel/tire combo. however, since you have that 2" BL, they should fit. ive got 33x12.50 R15s w/ 2.5" of lift, and lotsa pounding/ trimming on the firewall and fenders
(post 700 woohoo)
-Casey
Old Oct 1, 2004 | 04:26 PM
Was in a rush earlier..
Sorry about that! I usually try to read carefully but haven't been doing that lately...
Old Oct 1, 2004 | 04:33 PM
keisur's Avatar
I could be wrong but I think Steve Schaefer tried 35's on his 3rd gen. I would say if he fit 35's then 33x12.5's would fit with the same mods he made.
http://www.fastq.com/~sschaefer/thirtyfive.html
Old Oct 2, 2004 | 01:23 AM
I should ask him, but Im not worthy to lick any dirt off of his 35s. he is all knowing. But a little side note, I saw a 3rd gen runner at my friends shop on 16.5x14 welds wearing 35s and it looked awsome. I am jealous
Old Oct 2, 2004 | 03:46 AM
keisur's Avatar
I know what you mean, I'm not worthy either and I cry everyday on my way home from work because of it.
The next set I throw on will be the 305's.
Old Oct 2, 2004 | 10:25 AM
Im still lost on this debate though. I was reading on another thread that they dont recomened running a 12.50 on a 10 inch rim. So would't it be better to run the 285/75/16 on my current 16x10s. One day I hope to achive the level of Schafer, but in the scheme of things your doing better than me Keisur, your already locked and loaded
Old Oct 2, 2004 | 03:47 PM
keisur's Avatar
16x10's are fine for 305's. I know I can put them on my 16x8's which is why I went with that width for my 285's, thinking ahead. According to BFG, 16x10's will work for what your looking to do. http://www.bfgoodrichtires.com/asset...rain_ta_km.pdf
as for the scheme of things, aw, I have a family to support so I'd rather not starve them to be the coolest. just enough to get me through the terrain I run is what I say. I'm done with the offroad performance mods for a while now unless I get an unpassable deal on a winch.
Old Oct 3, 2004 | 03:23 AM
So you think that the 33x12.50 16s will clear the lift with no problomes. Or is it better to go with the 282/75/16? I just want to make sure the tires dont rub at anytime. But sad to say, I only have a 2wd, but when I get some money Im gonna lock it pre-runner style.
Old Oct 3, 2004 | 04:55 AM
keisur's Avatar
I rubbed with a 3" susp lift and no body lift. I installed a 2" body lift about a month ago and I haven't rubbed since. So I can only speak for my setup. with the stock front bumper the valence will need to be trimmed a little on the bottom edge closest to the tire with the 285's. I would also say that whether or not the 33x12.'s rub will depend on the backspacing of the rim. you want to get as small of a backspace as you can. I think I'm running 4.25" backspacing and they have about an inch or 2 clearance from the a-arm.
Old Oct 3, 2004 | 12:34 PM
I dont mind the trimming, of the bumper. But did you have to grind down the pinch weld in the front rear fender. I read that some people had to do that.
Old Oct 3, 2004 | 12:50 PM
keisur's Avatar
yea, i just took a 2lb sledge and beat it flat then sprayed some paint on it. no sense in trying to make that kind of stuff look pretty.
Old Oct 3, 2004 | 03:03 PM
Was there any seperation in the pinch weld? No comming apart, leaking, or rusting in that area?
Old Oct 3, 2004 | 03:15 PM
keisur's Avatar
No it won't leak. basically you just beat it (bend it over) to the inside of the wheelwell.
Old Oct 3, 2004 | 04:25 PM
So Just..... beat it.....beat it.....(something something)......Show them how funky.....
Sorry I couldn't resist it. With pounding of the pinch weld, which way did you pound it flat. I figured that I would pound the weld twords the engine, to prevent it from cutting my tire if anything happend over time.
Thanks for you help
Old Oct 3, 2004 | 04:38 PM
4runner4me's Avatar
You will be able to fit 305/70 not problem. I am not sure if a 315/75 will fit beings your truck is 2wd and 10 inche wide wheels. I would not put any thing but a 12.50 inche wide wheel on a 10 wide wheel. I bet 265/75 look crazy on 16x10.
Old Oct 3, 2004 | 05:11 PM
keisur's Avatar
Thanks for you help
that's what I meant when I said "beat it (bend it over) to the inside of the wheelwell."
