Camshaft Q
Camshaft Q
Hope it is ok to post this question here. I have a 83 Chevy Scottsdale, it was my girlfriends, but has become my truck now. She let her brother drive it after she got her 4Runner, and he jacked it up. It was perfect. He hit a couple of street signs, scratched the hell out of it, and parked it at their Moms house. We went to move it a long time ago, because after their Mom got a divorce, the house became a rental, and it couldn't stay there. So I climbed in and started her right up. Put her in drive and.. NO POWER!! I mean I could floor it and she would start to putt along, but it was horrible!! She had a hard time on a couple of hills, and I had to punch her to get to 45. So we got it to her dads, and there she has sat for about 2+years. I want to get her up and running again, because we need a pick-up, and before her brother got a hold of it it was a great truck. I'm thinking it is a flattened camshaft that is the problem. That punk was seen power braking it a few times, and driving like an a$$. What do you guys think? The cams would be a pretty easy fix, so I think I should get some thoughts from you guys, just in case I am telling myself that after I put in new cams all will be well. Any help would be great. I hope to get that 350 roaring back to life ASAP.
Thanks!!
Thanks!!
Does it smoke at all? I have never heard of a cam wearing to that extent prematurely. I would have to wonder if the a hole didn't run it out of oil and toasted the rings.
No smoke, and it had plenty of oil...dirty (dark) oil, but plenty of it. Engine sounded great, but it took allot of RPM to get any speed out of it.
BTW did I mention he went through two brand new tires!! The rear ones of cource, the front tires still look good. That boy Power braked ALL OF THE TIME!!
I doubt it's the cam. I pulled a cam out of my 360 duster that was completely flattened on three lobes and well on its way with the rest of them and the thing was STILL hotter than a popcorn fart.... and sniffed so clean on emmissions they ran it a second time because they couldn't believe they didn't screw up the first test!
If the thing has been sitting for two years+, then I would suspect dead gas first, sticky/plugged injectors second, timing third, bad plugwires/cap/rotor functions fourth, and.. um... I'd have to see what it's doing in person beyond that.
If he was seen pwr braking then I would also check the trannie.....the eng is putting out the power but the box that is getting the power can transfer it to the wheels.....
OOOooo yeah... If that's a slush-box, and he was prone to powerbraking, it's possible he swelled the Tq convertor resulting in MASSIVE slip. Those things rely on specific tolerances to function properly, and if you build up too much pressure in the 'verter you can swell the case and open up those tolerances allowing fluid to slip past the impellers/stators.
All things considered, i would have to vote transmission/ Tq converter. But I wouldnt tear into without checking timing, plugs, wires, compression, cap, rotor, and that the carb isnt too ˟˟˟˟ up ( he might of tried a little carb adjustment himself ) the gas and seals.
Yeah, now that I think about it more there's a few things in the tranny that could cause that. In order of easiest to hardest to troubleshoot:
Low tranny fluid (if you can't figure this one out, put the wrench down and back away from the vehicle)
Loose bands (can be adjusted from the outside without dropping the case)
Swelled Tq convertor (can be replaced without opening the case)
Worn clutchpacks inside the tranny (gotta crack into the case for this one)
Have fun!
Bumpity-bump.
Any updates?
Any updates?
Thanks again all!!
kawazx636
07-03-2023 03:03 AM
foampile
12-18-2022 01:29 PM
kawazx636
10-06-2021 03:03 PM
