budget throttle response?
Old 04-11-2010, 05:05 AM
noneckrex's Avatar
what are some ways to gain better throttle response?
if this helps any, i just ordered a magnaflow muffler, airraid throttle body spacer, and a k&n cold air intake for my runner. I am told i will gain some power from this combo but i also want a gain in throttle response... any input is appreciated.
Old 04-11-2010, 05:19 AM
eddieleephd's Avatar
what you said is what you need to do to get this!! intake and exhaust!!
Old 04-11-2010, 07:11 AM
Philbert's Avatar
add a header to the mix - that should help
Old 04-11-2010, 07:33 AM
Blue_petersen77's Avatar
EGR mod helped mine with some throttle response and you could always check the TPS
Old 04-11-2010, 10:20 AM
pendrag's Avatar
It's worth your time to clean the throttle body, Idle Air Control Valve, and Mass Air Flow Sensor if you haven't already.
Old 04-11-2010, 11:14 AM
noneckrex's Avatar
how do you clean the throttle body, idle air control valve, and the MAFS??? i too am a newbie trying to lean on the fly.
Old 04-11-2010, 12:15 PM
pendrag's Avatar
Throttle body and MAF:
http://www.4runners.org/writeups/throttle/index.html
If you're taking the TB off to get at the IAC, just clean the TB while it's off, as you'll get a better job done.
https://www.yotatech.com/forums/f123...ac-pics-92286/
Old 04-11-2010, 12:28 PM
noneckrex's Avatar
sorry for the dumb questions... but what is the TB? what does that stand for?
thanks for the link...
Old 04-11-2010, 12:50 PM
rebelrunner's Avatar
TB stands for throttle body.
Old 04-11-2010, 01:02 PM
noneckrex's Avatar
o that makes sense
Old 04-12-2010, 05:03 PM
Ironmike4x4's Avatar
You could have saved you lots of money and same or better HP gains by not getting the K&N kit by doing the deckplate mod. Search the wiki section and you'll see it.
Old 04-12-2010, 05:05 PM
Yukon's Avatar
Or you could have bought my K&N!
Cleaning the TB and stuff is actually what gave me the most noticeable change in response.
Old 04-13-2010, 11:17 AM
This is actually not near as good as the bruteforce dryfilter cold air intake but will yield better than the deck plate mod!
and yes cleaning the TB will help a lot.
But as some one said earlier a header is the next option and if you want more after that then the supercharger is better than the turbo set ups but the turbo is cheaper~
Old 04-13-2010, 12:51 PM
noneckrex's Avatar
how much do you want for your k&n???
Old 04-15-2010, 05:49 PM
or you could rig up a leaf blower to the intake and make a cheap supercharger hahahahaha
Old 04-15-2010, 05:55 PM
Gerdo's Avatar
By the way I have heard that the TB spacer does nothing.
You may get a little gain from the muffler and the CAI but not much.
Old 04-15-2010, 06:44 PM
you will get throttle response however the horse power gain will be minimal ..... for true HP gain you will need a Forced air and/or header
Old 04-15-2010, 07:41 PM
3w41d's Avatar
that parts list doesn't sounds like budget to me. return that throttle body spacer. it really doesn't do anything. do the TRD O gasket mod instead
https://www.yotatech.com/forums/f2/t...gasket-166753/
Old 04-16-2010, 08:07 AM
psraff's Avatar
Second that. I've heard from many people the TB Spacer does nothing (maybe make a little whistle noise or something like that).
I have a K&N Kit on mine. It helped a little bit, not enough on our engines for the money. It's always a sore topic on here for some reason. I personally like K&N and never had any negitive results from them. Others would rather eat their young then to put one on. Save and get a snorkle maybe.
I've heard good things with the TRD O Gasket and I plan on doing it myself someday.
Something no one has listed yet is check the cables on your TB. Tighten them (they stretch \ loosen over the years)
There is also a thread on here stating the "Deckplate Mod" doesn't do anything either. He had some great science backing his statements. I've never done it so I have no opinion on it.
Old 05-06-2010, 01:39 PM
jrm
jrm's Avatar
Combine the elbow & ISR mods
with the muffler. I did the ISR, elbow mods and installed a dynomax super turbo muffler. Once i reset the EFI fuse and started using 89 octane fuel the throttle response and pull is improved a lot. yeah me
Quick Reply: budget throttle response?
