broken stud on top of Donahoe coil over
Just noticed today one of the studs on my new Donahoes is sheared off.
How does this happen ??? the shock is only 4 months old. :pat:
My guess? Too much make-up torque during assembly (manufacturer) causing the stud to have either tensile or torsional failure. Basically like over torquing a bolt and snapping the head off of it, only in this case, it was torqued just enough to stay together but still cause a stress fracture that eventually completely failed. If you could post a pic more of a top view looking down at what's left of the stud it'd be easier to diagnose.
Looks like it was overtightened during installation, it would be quite easy to remove the broken stud, but you'll have to remove thw coilover assemble to gain access.
As long as your not taking it offroad, the 2 remaining blots will hold it in place.
Will I be able to just replace that stud or will I have to get a new top for the coilover ???? Heres a better pic.
Oh. I thought you were talking about a center bolt, like at the end of the piston rod or something.
I wouldn't worry about it much but just fix it ASAP. Like Bruce says, don't wheel with it like that.
what would be the easiest fix. I have contacted Donahoe but have not recieved a response back. can I just repace that stud or do I need a whole new piece????
I dont, what would be the easiest fix. I have contacted Donahoe but have not recieved a response back. can I just repace that stud or do I need a whole new piece????
It sounds simple and hopefully it is, but this is a male stud inserted in to a top plate Im not sure how you get it out. it does not go through the plate.
Two ways to remove that broken stud, first use vice grips to unscrew the stud out of the top plate. If you have a welder lay a nut on top of the stud and weld it, then simply unscrew it out.
the1998sr5
15
07-14-2020 08:35 PM
mr_manny
07-31-2015 10:39 AM
whereAreMyPants
07-22-2015 03:32 AM
