Broken ignition/steering lock cam
Old 09-11-2014, 03:27 PM
Busajoe's Avatar
I have a 97 4 runner limited 4x4 the cam gear below the key lock cylinder in the ignition has broken off inside the little key hole at the very bottom.. It's turned to the ACC position and I cannot get it out... It needs to be turned back to line up with the slot. Any ideas.? Can this even be replaced? Toyota wants $300 for a whole new ignition.. I cannot find any info online about this problem. Car won't start.. Luckily it broke in my garage in the ACC position. I will try to post a pic of the part that's broke.. Not my part but a pic I found online.. Any help would be OUTSTANDING.. I'm at my wits end trying to repair it.
Old 09-12-2014, 04:45 AM
wyoming9's Avatar
Red face
Remove the ignition switch
get a used one
have lock rekeyed to your key done!!
Remove ignition switch take to good automotive lock smith have repaired.
another one replace the complete steering column have ignition rekeyed to your vehicle
All options should come in well below the cost of new.
Pictures would be a big help.
bigjstang
08-25-2021 12:41 AM
westonian18
05-01-2020 06:38 AM
lectric80
08-11-2015 12:02 AM
cgilley
07-25-2015 10:55 PM
jon.r
07-11-2015 03:34 PM
Quick Reply: Broken ignition/steering lock cam
