brake problems
Old 01-07-2012, 03:45 PM
remmi's Avatar
brake problems
Hi new to the site here very helpful in the past so I thought I would join. My son has a 97 4runner sr5 and we did a brake job this weekend on it. Two new wheel cylinders and new calipers. I also installed a new master cylinder. Bench bleed the ms then all four brakes in the proper order. There are no air bubbles in the tubing when I bleed the brakes. Get good pedal pressure with the truck off but when I start the truck the pedal sinks to the floor. There are no external leaks. I need some help!!! Thanks
Old 01-07-2012, 03:56 PM
enapa's Avatar
Connected vacuum lines back up correctly? Im assuming you pumped pedal after start up?
Old 01-07-2012, 04:34 PM
remmi's Avatar
Yes lines are hooked up correctly. Yes pumped the pedal up after started engine but the pedal will hold pressure for a short time then goes to the floor.
Old 01-07-2012, 08:38 PM
enapa's Avatar
Well if thats the case i would look at the master cylinder. Is it an oem part?
Eggslinger
06-08-2019 03:32 PM
jasonty
41
12-23-2018 01:00 PM
skoti89
09-11-2015 07:46 AM
Johntom240
7
07-13-2015 12:18 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: brake problems
