| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Bought a factor hitch but
__________________
01 4runner 4x4 SE (stupid Cntr lock diff,VSC,TRAC) **Stuff I've wasted my money on** *front/rear chicken fence *clear corners *Hella 500s *Lexus HID *PIAA LED bulbs *ISR, Breather,DP Mod *Amsoil filter *husky cargo liner *Cobra STX II *SE badge *Griot's stuff* Alpine CDA-9815+Infinity Reference+12"Fosgate Punch/amp *BFG A/T 32s *Bilstein HD *Perforated Leather Seats...Buncha other stupid things "Uh....I dont know what I'm doing" -Ray http://community.webshots.com/user/ray0227 |
#2 (permalink) |
Check with the manufacturer to make sure you got all the parts.
#3 (permalink) |
Guest
You need metal nuts and bolts big enough so they don't fall through the mounting holes, and splice into exiting wire.
#4 (permalink) |
I bought this off ebay that's y nothing is included, can i just goto home depot and get bolts? this needs to be a forged steel right? and as for the wiring, i dont see the exiting wire for hitch, can someone tell me where to look for this? is it above spare tire?
__________________
#5 (permalink) |
The back nuts sits on a long piece of metal to help you align them with the bolt (they a inside the frame. I don't how to do it with out those. Maybe you can get a mounting kit from the dealer or ebay.
__________________
Carsten -------------------------- 99 4runner SR5 4x4 5spd |
#6 (permalink) |
Guest
You can get any bolts you want. Some will get scientific with grades of steel and such, but reality of things is you will never generate enough force to shear any bolt. As for wiring, again, splice. Easiest way is to take both tail lights off, and probe wires until you find which is which, strip the insulation and solder the trailer harness to it.
#7 (permalink) |
oh so wiring is not prepared for this(no connector and such)...I thought it was. I called around for parts to toyota but they dont have it as replacement part. I guess I'll have to align the hitch myself since I cant get the factory bolts that keepts it aligned. Thanks for help guys.
Ray
__________________
#8 (permalink) |
Mark, if you're out there, can you describe the 4 bolts that mounts onto the frame? not the 2bolts close together that's mounted towards the rear bumper. I gotta know what to buy when i make a trip to this bolt place. Since you've flipped ur hitch I figure you know what it looks like. If anyone else know input is much appreciated.
__________________
01 4runner 4x4 SE (stupid Cntr lock diff,VSC,TRAC) **Stuff I've wasted my money on** *front/rear chicken fence *clear corners *Hella 500s *Lexus HID *PIAA LED bulbs *ISR, Breather,DP Mod *Amsoil filter *husky cargo liner *Cobra STX II *SE badge *Griot's stuff* Alpine CDA-9815+Infinity Reference+12"Fosgate Punch/amp *BFG A/T 32s *Bilstein HD *Perforated Leather Seats...Buncha other stupid things "Uh....I dont know what I'm doing" -Ray http://community.webshots.com/user/ray0227 Last edited by 2001Millrunner; 09-03-2004 at 10:15 AM. |
#9 (permalink) | |
Quote:
__________________
With enough time and enough money ya can fix anything |
#10 (permalink) | |
Quote:
http://www.kwikhitch.com/miva/mercha...gory_Code=wire There should be 3 holes in each side of the frame, but only 1 will be threaded, a special bracket with 2 nuts attached to it, slides into the inside of the frame, then you can mount the hitch assembly. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| The longevity factor for my truck. | theryanator | 95.5-2004 Tacomas & 96-2002 4Runners | 15 | 04-06-2006 03:48 PM |
| Fear Factor- would you do it? | shazaam | Off Topic Talk | 16 | 12-16-2005 06:49 AM |
| 3rd Gen Pucker Factor? | RunnerUp | 95.5-2004 Tacomas & 96-2002 4Runners | 16 | 09-05-2005 08:21 PM |
| Took my bling factor up one notch | Corey | Off Topic Talk | 6 | 08-26-2002 08:01 PM |
