Best method to clean mud out of front headlights
What is the best method to clean mud out of the front headlight housings?
(hole was deeper than I thought...)
Remove headlight assembly, take out the bulb, rinse with water till all the mud is out. Finally take a coat hanger or welding rod, tape a small piece of rag that will insert where the bulb goes and wipe the inside of the lense clean. Bend the rod to gain access.
Yeah thats what I had to do with my tacoma. I never could get it all completely out of the cracks though, i tried and tried and tried using alcohol and water, a rag and flat-head screwdriver. Good luck. you do have to pull the housing out though and re-install it.
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
rushw
07-18-2015 01:46 PM
icentropy
07-14-2015 10:23 AM
