"Bad" muffler on 2002 4Runner?
Originally Posted by ecchamberlin
Brian
are the 50 series the quietest flowmasters? Or is there another quieter series?
EDIT:
nope, the Hushpower II series are small limited space ones. You might try calling Summit racing and asking them, specifically about the 70 series. It is a larger muffler for Big Blocks, might have a stronger muffling effect than the 50 series. They look like they might be a little pricey though, like $170. The 50 Series SUV is only about $80 I think...
OK. Back to me
I fixed my rattling/vibrating muffler tonight!
I crawled under the truck and confirmed that it was indeed coming from the muffler itself. The muffler has an outer metal shell wrapped tightly around it, which is held on by 9 or so small tack welds. There is a very thin layer of insulation batting between the muffler itself and the muffler outer shell. As I was tapping the muffler (outer shell) with a rubber mallet, I shoved a long flat screwdriver between the two layers, and pried them apart a bit. The vibration sound decreased.
I then figured there must be a bit of dirt or loose rust between the two layers, and figured I had nothing to lose, so I might as well pull the outer shell off to see if I was right. A chisel and hammer made quick work of those little tack welds, and the outer shell came off no problem.
See picture of outer shell here.
Between the two layers, I found this. The pile on the left is the pieces of thin insulation that I removed. The pile on the right consists of dirt and pieces of loose rust - the source of the noise!
Now that the noise is gone, my muffler sits there with no outer shell (which I assume is only there for extra protection - to make the muffler stronger and to help slow down the rusting of the inner layer of the muffler.) I am considering cleaning off the muffler with a wire brush, buying a can of high heat paint, and giving the muffler a new rust resistant coating. Good idea? Bad idea? Not worth the trouble? Should I consider trying to re-install the outer shell on the muffler? (I'm not liking my odds of getting it on there as tight as it was before with a new layer of insulating material between the two.)
I appreciate the replies, guys. I guess the flowmaster 50 purchase and installation will be postponed to a later day.
Nice work!
I guess that I may have to take a close look at mine. My outer shell is nearly rusted off.
Cheers ,
P
#25
OK. Back to me
nice work getting up in there an investigating. If I were you I would probably try to treat the outer shell with a wire brush & high heat resistant paint then have it reinstalled. That outer shell may act as a rust protector AND heat protector.
#26
Originally Posted by ErikJeanna
Sorry, but I'd have to disagree with you on this one. I had the stock muffler and just installed the 24/30 MagnaFlow on Wed. That thing is loud as hell when you start it up and when accellerating from a stop. Once you get past 1st gear, it quiets down alot, but its' certainly not comparable to stock as far as loudness.
Road Bull
10-10-2015 04:55 PM
09-04-2015 09:27 AM
rushw
07-18-2015 01:46 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Poncho0206
07-10-2015 06:21 PM
