Argh... Time to fix the ARB Airlocker
Old Feb 13, 2005 | 03:47 PM
Ducky's Avatar
So there I was... putting my dash together, better make sure my compressor, locker and offroad lights work... compressor to full capacity on the tank... good... engage locker.... psssssssssst out the rear... what? that sounds like its coming from my fuel door... open door.. ahhh the rear diff breather...
Welp guess ill be fixing that along with my other things i gotta do...
like 90K service... Ugh...
Old Feb 14, 2005 | 05:01 AM
aowRS's Avatar
Nothing is more important than figuring this TRAC crap out. Nothing. The 90k service can wait awile, and the ARB simply farted. No worries.
TRAC.
All in jest.
Andreas
Old Feb 14, 2005 | 09:37 AM
RIPPER's Avatar
Did you ever find out what caused the "pssssst"? Did it engage at all or not> Hope you get it fixed.
Old Feb 21, 2005 | 08:31 AM
Ducky's Avatar
Well took it in, good news the place I took it to said it's most likely a set of $2.00 seals which they are ordering in, the bad news, it will be about 200.00 in labor to install the 2.00 parts since they have to practically uninstall/reinstall the locker.
Old Feb 21, 2005 | 09:48 AM
aowRS's Avatar
Ducky,
Good luck with the locker. Hopefully that's all it is.
TRAC?
Andreas
Old Feb 21, 2005 | 10:20 AM
Klaüs's Avatar
It's probably just the rubber O-rings in the copper collar. They will dry up sometimes and not hold a seal.
Did you first 'test' out your locker after your rig had been sitting for a while? You might want to check your diff fluid level, then drive your rig, then test it again. Sometimes those O-rings just need to get saturated again and they'll work just fine.
The O-rings do go out though, so it's possible that they did. It's quite an easy fix because all you gotta do is pull the locker/carrier out, change the rings and put them back in. Since your rear-end has allready been "installed" all the shims and everything are set, so it's not near as difficult as installing the locker for the first time. Depending on how it's installed, you might still need to get a case spreader tho.
Old Feb 21, 2005 | 04:20 PM
shazaam's Avatar
you know what it was on mine. The copper line wasn't routed right, it was pushed right up against the diff casing when the thrid was reinstalled. The copper line cracked at the base and basically had to be replaced. Then the line was rerouted as not to make contact with the diff casingEveryone thought it was the O rings, but they were fine. So if your ordering parts, make sure you order the copper line as well.
Old Feb 21, 2005 | 06:32 PM
Klaüs's Avatar
Well, the copper line is part of the collar that the O-rings fit into so it can get expensive....... but yes, a good thing to replace if the routing is bad. That would suck to have to change out the whole collar and line because of a crack or something.
Old Feb 21, 2005 | 07:05 PM
shazaam's Avatar
mine was still under warranty so I lucked out.
Old Feb 22, 2005 | 07:04 AM
Arnold's Avatar
I took my entire 3rd to ARB and they replaced the inner seal for free. They even gave me spare parts. If it's just the o-rings in the seal housing, you should be able to replace those easily.
Old Feb 22, 2005 | 07:24 AM
Ducky's Avatar
Ok so im new at this (had my locker installed somewhere)
ARB said I could take out the locker and the seal housing and bring it to them...
what do they want? lol... and is it hard to disassemble reassemble?
Hey Rob, Ill pay you 100 bux to help me lol....
Old Feb 22, 2005 | 07:28 AM
WATRD's Avatar
Is this the front or rear?
Ducky's Avatar
Opps Rear... lol.
Old Feb 22, 2005 | 07:30 AM
WATRD's Avatar
We could just pull the third and take it down there. Email me and we can chat.
Old Feb 22, 2005 | 07:32 AM
Ducky's Avatar
Emailed...
Old Feb 22, 2005 | 07:36 AM
snwbrdpunk16's Avatar
Shoot if you need an extra hand i wouldnt mind helpin out to see how its done, learn a little more.
Jun 1, 2021 01:51 PM
Whatever123
Sep 30, 2015 12:12 AM
Yota.Jay
Jul 23, 2015 08:08 PM
ptb12
Jul 5, 2015 01:49 PM
