ARB bumper with 2" body lift???
So I have searched and not found an answer. Is there a way to raise an ARB bumber to match a 2" body lift on a 98 tacoma? If I make the bolt slots longer I could get about 1/4" but thats all I've found. I know someone else must run an ARB with a 2" body lift so what did you do? Thanks for any help
thats what I was affraid of, I have no welder or torch... Guess I'll have to look for a good shop. Did you just cut down the center and off set the 2 halves 2"?
Thanks guys, I do wanna be able to winch with it so i guess i'll just leave it low and make some kind of gap guard. Thanks again for the help and pics.
Location: raleigh, nc for school chapel hill, nc for home
I had my TJM brackets cut and welded 2" higher and re-enforced with some added brackets and have no problem using my M8000 winch. If it is done well, you shouldn't have a problem
^^^ Agreed, just make sure you put gussets on the section of the mount down to the main body of the mount and it'll be plenty strong. Go for it dude.
Dont worry about it. ARB's dont have that good of an approach angle. for the amount of work you will be doing to keep it as a viable winch mounting point you could just build your own bumper.
06-01-2021 01:51 PM
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
