| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
#2 (permalink) |
1) wheres the pics? you can't give intro's without pics
![]() 2) maintenance, maintenance, maintenance 3) enjoy driving! |
#3 (permalink) |
hold onto your wallet. while this place has many money saving tips, this place will bleed you dry too!
![]() if you don't have the service records, visit the soon-to-be-phased-out maintenance section and see the stickied link. while there, there is a link that goes to the toyota maintenance database engine that will tell you what service items you need to do when you plug in your vehicle information + mileage. to me, mainteinance is job #1 when buying a used car. then the rest can follow since its for the wife, detail it and put a little bow on it ![]() bob |
#4 (permalink) |
ok pics a comin'!!
I should post pics this evening
I did find one thing that requires immediate attention. The right rear running light isn't working, the brake part does work but not the running light. The left rear light works fine. Does anyone have a wiring schematic for the 1996 4runner limited so I could run down the problem (I have already replaced the bulb) Thanks |
#5 (permalink) |
you should consider getting some new plugs, a fuel filter, and cleaning the MAF sensor and throttle body, and possibly new belts.
next, you should consider new coil springs and shocks to get the ride up to par. congrats on the purchase. |
#6 (permalink) |
didn't think about the MAF thanks,
The truck is level and the shocks check out, do you still think I need new springs? Thanks agian for the input. |
#7 (permalink) |
If the shocks and coils are original w/146k on 'em you should replace them both.
__________________
'99 4Runner Highlander 4wd E-locker,rear diff and deckplate mod * 265/75/16 Nitto TerraGrapplers * Yakima Load Warrior rack * clear corners/signals * Tacoma skidplate * Silverstar lamps/fogs Alpine CDA-9831,Bazooka EL Series 250w amp,MTX 10" sub |
#8 (permalink) | |
Quote:
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#9 (permalink) | |
Quote:
If not, then check all the fuses (not likely if other bulbs work, but should check anyway). Still no go, then start going at it with your multimeter and a wiring diagram.
__________________
#11 (permalink) |
Did you check the bulb?
__________________
Thanks Lance 98 4Runner Limited Web Wheeler |
#12 (permalink) | |
Quote:
#13 (permalink) |
Here are the photos, my wife is cleaning the runner up as I type, she is a good spouse. (I am dead if she reads this!!!)
#14 (permalink) |
Not to hijack because im sure it will help flightservie with his new runner also, but anybody know where that database is Bob was talking about?
#15 (permalink) |
Staff
http://smg.toyotapartsandservice.com/index.php
There's the direct link. http://www.yotatech.com/showthread.php?t=38266 There's the link to the thread. Hope that helps, Fink
__________________
1985 4Runner 22RE 4WD "Ratchet" 2007 Tacoma Double Cab SB 4x4 V6 TRD Sport AR-TTORA "My work number is 9-1-1." |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Newest member of the family. | yoda-g2 | Off Topic Talk | 1 | 05-22-2006 01:57 PM |
| Daystar 2.5" Lift Kit 1996 4runner Limited? | T-A-Z-M-A-N | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 10-08-2004 09:50 AM |
| The official "How many miles on this part?" or "Is this normal wear?" thread.... | 4RUNR | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 11-28-2003 10:10 AM |
| A New "Family" member | Dr. Zhivago | Off Topic Talk | 7 | 04-09-2003 05:55 PM |
