another PO171 code...
Old 09-14-2006, 09:29 AM
MTL_4runner's Avatar
Originally Posted by ebelen1
Weird thing is the code turned off this morning. Anyone know if this means the CEL cleared itself and I have no more issues, or what?
The ECU may turn the CEL on or off depending on the conditions seen, but I wouldn't count on it staying off.
Old 09-14-2006, 09:33 AM
04 Rocko Taco's Avatar
Agreed. You should at least get your contingecy plans in place and source some parts for when it comes back on, because it probably will.
Old 09-14-2006, 10:44 AM
Potomacduck's Avatar
Don't spend too much time trying to diagnose a bad MAF sensor. I learned the hard way. I had a bad sensor which was running the mixture way too rich. I tried cleaning it, ignoring it, etc.
The bad fuel/air mixture tanked my catalytic converters. I'm embarassed to tell you what that cost me. MAF's are cheap by comparison!
Old 09-25-2006, 12:34 PM
ebelen1's Avatar
Update: 9/25/06
Again, yotatech comes up w/ the right answer. I changed my MAF (thanks to Evan at Northridge Toyota for a great deal) last week and no CEL. I didn't want to post until I had a week code-free.
I did change my A/F sensor first, which may not have been the reason for the code but at 100k miles, I figured I'd need a new one sooner or later.
Old 09-25-2006, 02:44 PM
  #25
Update: 9/25/06
Good to hear Edwin, I think you made a wise decision to change the A/F sensor anyway. If you want to get optimal gas mileage, that sensor needs to be working 100% when giving feedback to the ECU. Glad you got it solved.
Old 09-25-2006, 03:30 PM
  #26
ebelen1's Avatar
Only thing Jaime is I'm not getting mpg w/ both a new A/F sensor and MAF sensor. I wish I was...
Old 09-26-2006, 04:56 AM
  #27
Stevo3's Avatar
I just replaced my MAF, no luck getting rid of the code. But, what is this A/F sensor? i thought it was the MAF sensor. I guess im wrong, Sorry for being an idiot.
Old 09-26-2006, 05:29 AM
  #28
In most cases the P0171 indicates a bad MAF sensor (sometimes they can be cleaned, sometimes they need to be replaced as it did in Edwin's case). The other possibility for the code is likely the A/F sensor (on trucks 99-02, the front O2 sensor was replaced by what is called an Air/Fuel sensor). There are a few places to get them cheaper if you do a search on YT (Evan - Northridge, Phil - strapp22 or URD).
Old 09-26-2006, 05:41 AM
  #29
Stevo3's Avatar
Well then that is why i dont know about the A/F sensor. My rig is a 96 runner.
But that is my next step is to change the first O2 sensor. I just bought a new MAF and no luck with that, just a huge dent in my pocket . Maybe ill pick up an O2 sensor today, ofcoarse an OEM Denso. The NAPA by me carries them for $100, AutoZone/Checker for $130. And I seen Gadget has them for $80. Ill just get one now, instead of having to wait for shipping. Hehehe, Ill just milk the clock today for 1.5 hours. to make up for that $20.
Old 09-26-2006, 05:59 AM
  #30
ebelen1's Avatar
Good luck. I just thought it was the A/F (O2) sensor as the mileage was showing that it may be needed. It's pretty rare as I've searched but I don't see many changing MAFs (unless they are s/c'd and want to get a Supra MAF).
Did you try to also search for vacuum leaks as this can cause the same code? I did check but didn't notice anything on mine.
Old 09-26-2006, 06:15 AM
  #31
On the 96-98's for whatever reason, the MAFs rarely go "bad" compared to the 99-02's......sorry this bit of advice comes a little too late to be of any help after you dropped a few C-notes on a new MAF. My bet is your front O2 sensor being the culprit.
Old 09-26-2006, 09:30 AM
  #32
Stevo3's Avatar
Well, My truck is S/C'd, and didnt the light didnt come on for about 500 miles after it was put on. If any knows a reason for that. Ill try the O2 sensor as i said and see if that helps it. Thanks for the replies!
Old 10-02-2006, 05:30 AM
  #33
Stevo3's Avatar
Well, After looking over the hoses on my truck, I did notice a Hissing noise comming from the S/C. All my hoses are correct and okay. But I have the GEN I S/C (the grey one). And the hissing is comming from the "thing" near the bypass vavle. I dont know what its called But its like a rectangled piece that fits into the intake part then turns into a cylinderish piece next to the bypass valve.....
Anyways I think this is the main culporate to my "Bank 1 Too Lean" code. As the truck gets up to temp, Its starts to run pretty rough (engine rocks back and forth). I then place my hand over the part thats leaking and it idles back to normal, which is smooth running. Is there anyone out there with they Grey S/C? I think Gadget has one but I would think he has upgraded to the newer one.
My Question is now, am I able to use the Hi Temp Gasket maker to put in the part that is sucking in extra air? Because I cannot find anything about a true Gasket for that area. Thanks for the help!
Old 10-02-2006, 05:52 AM
  #34
ebelen1's Avatar
I think it's better you start a new thread w/ your question or it may get buried. There's a pretty active s/c group here that have been very helpful to those having issues...
Old 10-02-2006, 07:11 AM
  #35
I think AJatx just had almost the exact same issue you are having:
https://www.yotatech.com/forums/f2/p0171-trouble-root-causing-95672/
An auto parts store should have o-ring kits with what you need.
jamacee
11-13-2012 08:37 AM
toykidd
14
02-02-2012 03:54 PM
pfbmgd
13
07-14-2009 10:56 AM
ROOFGOOF
19
07-04-2008 03:57 PM
Quick Reply: another PO171 code...
