Another body lift question, 99 4runner
Old 03-21-2004, 08:17 PM
Stive2699's Avatar
I have a 99 model and its only 2wd. i just want to put 33's on it but also have it kinda high. I currently have 3" revtek coilspacers and will be putting them on by the end of this week. I would like to purchase a 3" RB Body Lift. I do not know that much about working on this type of thing so im not sure if i could install this myself. dont no how to weld or anything thing like that. What im really wondering is the PRICE for the complete 3" b/l (everything from the blocks to the bumper raiser brackets) that some one has done on there 3rd gen 4runner. I have looked on RB's website and cant get the right pricings because im not sure what all I need. Also im wondering on how to install this after I purchase it... any ideas? im gonna have around 400$ soon to spend on the b/l so hopefully it wont be more then this.
(i have tryed to search the forum for this but cant find the price on 3" and not specificly what i need to know.)
THANX!!!
Old 03-21-2004, 08:40 PM
4Crawler's Avatar
Here you go:
Body Lift Kit Pricing Info:
http://www.4crawler.com/4x4/ForSale/BodyLiftPricing.txt
Code:
97-02 4Runner Body Lift Kit:
  Kit:           Cost/1"  Cost/2"  Cost/3"
  B              $ 48.00  $ 62.00  $ 76.00  (Ult. blocks only)
  D              $ 73.00  $ 87.00  $101.00  (Kit B + h/w only)
  F              $ 83.00  $ 97.00  $111.00  (Kit D + front bumper brkt)
  SE             $ 25.00  $ 32.50  $ 40.00  (Steering Extension)
  RAD            $ 10.00* $ 10.00  $ 10.00  (Radiator Drop Bracket)
  COLOR          $ 10.00  $ 10.00  $ 10.00  (Custom color lift blocks)
  HD             $ 15.00  $ 15.00  $ 15.00  (Upgrade Gr8 Hardware, rec on 2"+)
  Typical Kit    $108.00  $139.50  $161.00  + shipping**
                 (F+SE)   F+SE+RAD........  (Typical kit contents)
Notes:
See above referenced file for description of the kit letters
Kits B/D/F/H are mutually exclusive, that is kits F and H include kit D/B
(*) Optional, subtract from kit price if included and not needed
(**) Zip code/country needed for shipping and sales tax calculation
(***) Requires drilling, 2"+ flip stock bumper brackets & redrill holes
Front bumper bracket on 2000+ 4Runner/2001+ Tacoma, will need to remove
or raise the inner bumper for the outer bumper to clear when lifted
Mossback74's Avatar
DO you have an auto or 5 spd trans?
Old 03-21-2004, 08:46 PM
Stive2699's Avatar
Auto Trans
Any ideas on how to install this body kit? prices on how much it would be at a shop.. cuz i dont no much about doing stuff like this...
Old 03-21-2004, 09:09 PM
Albuquerque Jim's Avatar
Where do you live?
Old 03-21-2004, 09:10 PM
4Crawler's Avatar
Originally Posted by Stive2699
Auto Trans
Here's the installation instructions:
http://www.4crawler.com/4x4/ForSale/...ft_HowTo.shtml
http://www.4crawler.com/4x4/ForSale/...er/index.shtml
Old 03-21-2004, 10:28 PM
PoBoy's Avatar
Auto Trans
Dont take it to a shop. Do it yourself...seriously. It's a great beginner's job. Just need a couple sockets and a jack. Roger Brown (4Crawler) has some great instructions and we can help you along the way if you have any troubles. It really is easy though...many many members here have done it themselves thinking they couldnt do it. I myselft thought the same, but I gave it a go...couldnt have been happier I did. You dont need to know a thing...just have to have the right sockets, 2x4, a jack, and some patience.
Roger Rocks by the way...buy from him!
Old 03-22-2004, 02:57 AM
Stive2699's Avatar
Originally Posted by Albuquerque Jim
Where do you live?
Atlanta Georgia
Old 03-22-2004, 06:16 AM
Stive2699's Avatar
Originally Posted by 4Crawler
Here you go:
Code:
Notes:
So if I where to go with a 3" bodylift I would choose lift kit F for 111 dollars plus tax. Would I have to extend anything?
Thanx
Old 03-22-2004, 06:35 AM
4Crawler's Avatar
Thanx
You'll also need some sort of steering shaft extension (SE) and some sort of radiator reloation (RAD) as noted in my typical it contents.
Old 03-22-2004, 06:46 AM
44Runner's Avatar
you only want to run 33s but you want 6 inches of lift? :wtf:
Old 03-22-2004, 09:07 AM
Stive2699's Avatar
Yeah, :wtf: is wrong with that????
Old 03-22-2004, 09:13 AM
4Crawler's Avatar
Its way more lift than you likey *need* to fit that size of tire. But a lot dependson the width and brand of the tire and the width and backspacing of the wheels you are planning to run. Wider tires and/or wider/more offset rims will push the tire out wider and make fitting it harder, especially up front while turning.
Most folks do a 2"-3" suspension lift and a 1"-2" body lift for the 285s on stock wheels. Fits and works well. Lift as much as needed but as little as possible.
Old 03-22-2004, 09:14 AM
44Runner's Avatar
too much lift for too little tire...
IMHO it will look kinda retarded and just be an all around bad idea.
EDIT: Looks like Roger beat me to the punch...
Old 03-22-2004, 09:17 AM
TDiddy's Avatar
I think what Dave is getting at (correct me if I'm wrong) is that you don't need a 3" body lift to clear 33's. A3" BL will be more complicated to install because you'll need to deal with other necessary modifications. See #3 on RB's body lift FAQ's:
"3. What about taller body lifts?
While I categorize a 1" body lift as mild, there are many folks running 2" and 3" body lifts. 3" is pretty much the maximum lift you should consider on the stock mounts. Above this and you should consider raising the mounting bracket on the frame to reduce the leverage caused by the taller blocks.
At 2" on most Toyotas, you will find that in addition to the items that a 1" lift affects, you will need to extend the hydraulic line to the clutch slave cylinder.
A stock front brake line works well for this.
At 1" the radiator shroud was probably OK as-is, but at 2", you should drop the radiator to re-center it on the fan.
Same story on the shift levers, while modifications are optional at 1", they will probably need to be done at 2" and for sure at 3"
You'll also need to let the steering shaft lengthen a bit and chances are the upper engine ground strap may need to be lengthened.
With a 1st gen. 4Runner, a 2" lift allows you to raise the gas tank 2" using the existing pickup mounting holes on the cross member.
At 3", in addition to the above items need attention as well as dealing with fuel lines at the gas tank. One option at the 3" stage is to also lift the entire drive train by a similar amount.
For example, the engine and transmission could be raised for additional break-over angle, the fuel tank could be raised, etc. This will restore many of the interference areas to their original position."
EDIT: looks like everyone beat me to it!
Old 03-22-2004, 09:43 AM
44Runner's Avatar
But at least you gave a complete and well thought out answer...
Old 03-22-2004, 09:50 AM
waskillywabbit's Avatar
Talking Run 33s
I ran 33s on a 2" RB body lift with very minimal rubbing. Now I have about 5 inches of overall lift and 33s are looking small
Old 03-22-2004, 11:50 AM
Stive2699's Avatar
Thanx for the replies guys!! will consider all.
hopefully ill have everything on in about 2 weeks hopefully... maybe lil bit longer.
06-01-2021 01:51 PM
Avenged
07-09-2015 07:55 AM
God's Bounty Hunter
07-08-2015 12:54 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Another body lift question, 99 4runner
