Air Fan Blower Squeak
Old 03-06-2003, 01:25 PM
HBoss's Avatar
Hey have any of you 3rd gen owners developed any squeals from your interior air blower motor?
The motor behind the glove compartment has developed an annoying intermittent squeak. It either needs to be silicon-sprayed or replaced.
Has anyone here ever had this problem? Have you tried lubing/cleaning it, or have you simply replaced it?
Old 03-06-2003, 01:51 PM
frick's Avatar
My 95 P/U is starting to have an intermitten squeak in the blower motor as well... I'm usure what to do to fix it...
Eric
Old 03-06-2003, 01:55 PM
HBoss's Avatar
I find that if I shut the fan off and then turn it back on, it goes away for a bit. Or if I hit it w/my maglite it goes away.
I saw 2 screws at the bottom of it & I have to do some work on the Runner tonight, so I'll see if I can get a closer look at it then.
Old 09-08-2003, 05:15 AM
ugadawg95's Avatar
i took my blower motor apart this weekend because i was having the same problem...squeaking randomly, i could't believe what i found! the whole fan was clogged with leaves and cigarette butts. when i say clogged, i mean clogged. i couldn't even believe the fan would even turn. so i cleaned it out and no more squeaking. how does trash like that end up in the blower fan assembly? is there not some kind of protection from debris entering the fan? all in all not too hard to do...took about an hour if anyone wants a writeup i will be happy to provide one.
Old 09-08-2003, 11:24 AM
rleec's Avatar
I would DEFINITELY appreciate a write-up! I rarely use my fan on low speed due to the squeak.
Thanks,
Rick
Old 09-08-2003, 11:33 AM
rimpainter.com's Avatar
Someone was using your rig as an ashtray. That's crazy!
Old 01-09-2006, 06:41 AM
mjwalfredo's Avatar
Sounds like the mechanics at my local dealership. I found cig butts all over my engine bay the last time I took it in.
Old 01-09-2006, 08:10 AM
eric-the-red's Avatar
Here's a write up on cleaning the fan
http://www.4runners.org/articles/fan/
Old 01-09-2006, 08:20 AM
4Crawler's Avatar
Here is a writeup I did on overhauling the blower motor in my '85:
http://www.4crawler.com/4x4/CheapTri...ml#MotorRepair
Lube the bushings, clean the fan and in my case replace the carbon brushes in the motor.
Old 01-09-2006, 08:29 AM
mjwalfredo's Avatar
Thanks for those last two posts guys, that's awesome!
Old 01-09-2006, 08:35 AM
MTL_4runner's Avatar
Yeah I had the squeek too and fixed mine (has not come back since).
Here is the thread where Bob's writeup came from and how I fixed the squeek:
https://www.yotatech.com/forums/f2/heater-ticking-sound-23595/
coryc85
09-09-2015 06:24 AM
PETDOC
08-18-2015 05:29 AM
jackiebrownia
07-20-2015 09:02 AM
1996Taco
07-20-2015 12:02 AM
msane99
07-17-2015 10:13 AM
Quick Reply: Air Fan Blower Squeak
