Aftermarket rotors??
I called Taylor Automotive and they said that it would have the same SKU, but if you put it in your cart, it would specify.
I added it to my cart, and yes it did specify, so I bought a pair!
Yea! I've been looking for some of these, and I got them both for $85, and shipping was free.
I can finally replace my worn to the limits and warped rotors.
Good deal.
Good deal.
wouldnt you need rear disc conversion to match the stopping power up front? I know this has been talked about before but I havnt seen any clear answers. Doesn anyone offer this conversion or would it be a PITA?
I don't recommend cross-drilled nor slotted for a truck application, but it does improve braking performance for typical street application. My brake pads life have REAL short life with cross-drilled/slotted rotors. I went through TRD pads in 1 year (brand new to squeaking).
If you race (not sure how many truly race on this forum) or do any kind of stressful driving, the drilled (or cast)/slotted rotors may crack or warp on you.
I bought a set since I was curious about these rotors. Cross-drilled save weight for motorcycles. Slotted helps the gas from pads escape for those pads that are gaseous. Street application brake pads are not as gaseous as some of the different race brake pad compounds out there. The best bet for stressful applications (racing or serious offroading) is to buy bigger rotors with bigger brake calipers since you want to INCREASE the braking surface area.
J
J
#26
Holy Crap!!!!
I went home for lunch today, and when I got there, I found the
Brembo rotors I ordered from Taylor Automotive yesterday!!
I about fell over.
I think Taylor Auto is my new best friend.
Oh, and dBikeman - According to Taylor's site, the 2wd, and 4wd with 16" wheels have the same part number on their brake discs.
I about fell over.
#27
Originally Posted by Lifer
My 2 cents is go for the Raceconcepts cross dimped/slotted rotors. Ive ran these with Performance Friction pads for around 2yrs.and they're awesome. Brake dust isnt an issue and stopping power/feel is 10 times better than stock. Raceconcepts will give the right rotor (Brembo's)for whatever you need. They're only a couple dollars more than stock and well worth it. Talk to Wood at Raceconcepts, he knows his stuff.
If you get the Performance Friction Pads from Autozone, there's no need to worry about pad life since they have a lifetime warranty. So when they get low, you just trade them out for a brand new set at your local Autozone for free.
#28
Bbeast, that's what I did. Ordered the Brembo cross drilled rotors and the PF pads. They were only $37.00 for the PF pad's and I will be at Autozone every 6 months! I think it's the best break setup I can do to my Taco!
#30
I got my new Brembo's all painted up and installed last night.
Yeah! No more vibration when breaking, and no worries about the rotors being under spec anymore!
I wish I would have found these sooner.
#33
Originally Posted by justinh
you painted your rotors?
#34
OK, so who still has their ported/slotted rotors without a problem?
I read Gadget's write up about his slotted rotors but he was saying that when the slotted warp, they return to a warped state very soon after turning...
Anyone have any problems yet?
#35
Do you have a part number for the right application? I checked out the website, but couldn't figure out which one was right for the 4runner.
#36
I just got my powerslots installed on Friday. They didn't make a big difference, but I think I have leaky axle seals making them do ALL of the work currently. I have the seals to install, just need a little time...
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
hiluxinargentina
09-30-2015 05:51 PM
