AfterMarket Back up light wiring question
Old 01-27-2005, 10:41 PM
Guest
Yoter's Avatar
Question AfterMarket Back up light wiring question
I have a set of Blazer brand 55W driving lights I have mounted to the rear bumper as my back up lights. they work great but I am using an after market toggle switch to turn them on/off. I want them to come on when I put my rig in reverse using the shifter. Can I just tap into the OEM wiring for the back ups? I worry I will fry the OEM switch if I do. Do I need a relay in there? Need a little direction as to completing this task. Ben
Old 01-27-2005, 11:14 PM
kyle_22r's Avatar
relay activated by your factory backup lights would probably be the way to go. that way, you could run a sufficient amount power on its own circuit to the lights
Old 01-27-2005, 11:18 PM
3car's Avatar
use a relay. i tried to run a pair of driving lights off the back up circuit of my work truck, and it didnt work out well. i needed a new fuse every time i hit reverse.
Old 01-27-2005, 11:20 PM
Guest
Yoter's Avatar
oh chit forgot to tell yuh. I am not running the oem lights on the tailgate. they are gone/unhooked. so it would only be the 55 watters.
Old 01-27-2005, 11:24 PM
3car's Avatar
i would still use a relay. cheap insurance aginst potental problems.
Old 01-28-2005, 12:28 AM
2001Millrunner's Avatar
Agree, and that's what I've done.
Old 01-28-2005, 08:15 AM
Guest
Yoter's Avatar
Alright its decided. I will run a relay but where should I put it? I figure I will ease up on the wire load and run each light off of each of the OEM wires in the tailgate. So would I install the relay near the switch? I have never hooked up a relay so I dunno. I am sure there is a write up on it in tech.
Old 01-28-2005, 08:23 AM
Cebby's Avatar
Don't go burning your truck down...
Fuse your hot lead.
http://www.installdr.com/TechDocs/999404.pdf
Old 01-28-2005, 08:28 AM
Guest
Yoter's Avatar
Fuse your hot lead.
Do I see a white box with red X cuz its a PDF file?
Old 01-28-2005, 08:36 AM
Cebby's Avatar
Good gawd.....
http://www.adobe.com/products/acrobat/readstep2.html
Download the free reader....
Old 01-28-2005, 12:18 PM
98LimitedCustomized's Avatar
Use this as a guide
http://www.classictruckshop.com/club...h/foglites.htm
This should show you what you need to know. I'd upgrade to some bigger wire, like 14 or 16 guage. I put my relay behind the plastic panel and screwed it to the metal back there. Your "switch" can just be tapping into the factory reverse lights, so when you put it in reverse the relay does its thing and your lights light up. USE A FUSE. This might get me in trouble but... fuses are like condoms, if you don't use one and bad things happen, nobody is gonna feel sorry for you!
GreenLion
06-07-2021 10:49 AM
gillesdetrail
11-19-2019 12:56 PM
Bru
06-23-2015 06:58 PM
TheManOutside
06-18-2015 03:32 PM
Corey
06-25-2002 11:13 AM
Quick Reply: AfterMarket Back up light wiring question
