99 4runner fog light wiring
Old 03-13-2010, 01:30 PM
antb00gie's Avatar
I am trying to install fog lights on my 99 using the factory wiring. I've seen the PDF upload of the wiring instructions, but there seems to be a difference in years.
https://www.yotatech.com/forums/f2/1...ctions-119070/
This shows I should tap into the B/R and G/B wires under the steering wheel (pins 10, 11) However my the wire I have on pin 11 is W/B. I went through anyway and the fogs don't work. On top of it all my dash lights went out and the dimmer switch won't function, along with my corner parking lights.
Can anyone help here? I've searched and searched and no clear answer has come up. I need to know which wires to tap into for my fog light switch.
Thanks.
Old 03-13-2010, 01:36 PM
eddieleephd's Avatar
First question I have were there stock foglights on this truck??
Usually when you install such accessories you use a relay to a switch and power off either a hot in run wire or the battery as well there are terminals in the fuse box in the engine compartment that are hot in run.
Old 03-13-2010, 01:39 PM
https://www.yotatech.com/forums/f123...umbers-102344/
look here for your fsm and you will be able to go through the wiring diagram to see what color wire you are looking for.
Old 03-13-2010, 03:30 PM
antb00gie's Avatar
THANKS!
From the FSM I figured the G/B wire on pin 10 is only on vehicles with DRLs, otherwise, pin 10 is W/B. Fogs are running, and thanks again for the FSM links!
And I somehow unplugged the "Tail" relay which caused my dash lights, corner parking lights, and license plate lights to go out. Plugged it back in and all is well.
Anthony.
Old 03-13-2010, 04:35 PM
Glad that was so useful and not a great big headache!!!
Have fun!!!
infinityisfive
06-16-2015 06:51 PM
CLin9383
7
06-25-2002 01:42 PM
Corey
06-19-2002 11:06 AM
95Runner
7
06-08-2002 01:02 AM
MRael
15
06-05-2002 02:20 PM
Quick Reply: 99 4runner fog light wiring
