'98 4runner gearbox
Old 01-23-2007, 05:33 AM
Choopster's Avatar
'98 4runner gearbox
My '98 4runner with manual tranmission seems to excessive slop in the gears when changing rather than a precise feel like I am use to in my '94 truck. Is this normal or can I correct? Thanks...
Old 01-23-2007, 06:04 AM
Bennito's Avatar
Depends what excessive means.
You'll find a number of threads with people trying to get rid of "notchy" shifting. You'll find threads with people talking about how to get smoother shifting. Excessive may mean there are underlying issues.
Options run from overfilling your manual tranny w/ aftermarket fluids to urd's short shifter kit. (think there's a replacement on the top of the gearbox that can be done as well)
EDIT - Bob's writeup on the shift seat bushing: https://www.yotatech.com/forums/showthread.php?t=76379
Old 01-23-2007, 07:46 AM
Choopster's Avatar
Thanks very much Ben. I appreciate the excellent information. Regards,
Old 01-23-2007, 01:25 PM
toyotaoffroad91's Avatar
try some redline mt90 awsome stuff worked great in my 91
Old 01-23-2007, 02:30 PM
Bennito's Avatar
That's the aftermarket stuff most use. I went with mobile1 fluid and didn't experience much improvement. I overfilled the gearbox via the standard fill port (jacked that side of the car up to get some extra fluid in the box). Looking forward I'll probably keep my eyes open for some MT90 and the bushing. Then I can drain my fluid, replace the bushing and overfill via top.
Though I'm really looking for an excuse to get the URD short shifter kit (http://www.urdusa.com)
Old 01-23-2007, 02:46 PM
1989toy4wd's Avatar
There is a bushing at the shifter that goes bad on these trucks, it is a very cheap fix, but while you are there, you might as well change the fuild, if it hasnt been changed for a long time...here is a write-up,
Old 01-23-2007, 06:08 PM
mobil1 i think is too slippery since its GL5, which could cause the syncros not to sync.(i am not sure on the newer 5 speeds) but GL4 is recommended for the tranny's which mt90 is. for the transfercase however gl5 can be used
Flying91
45
04-11-2024 04:39 PM
icentropy
09-16-2020 02:47 PM
coreyedwards7611
01-16-2016 06:38 PM
BeMiceElf
10-10-2015 09:40 PM
Poppie51
07-16-2015 06:16 PM
Quick Reply: '98 4runner gearbox
