98 4Runner Door Trigger Wiring
Old Sep 18, 2006 | 12:12 PM
tedp's Avatar
Hello All,
I've just completed installation of a keyless entry/alarm system on my 98 4Runner. I've found all schematics and wiring instruction necessary on this forum -- that's awsome!
The only tweak that would be nice to do involves the door trigger. The wire specified in all the writeups the black/white wire by the driver's door junction does not include the hatch. Is there a trigger wire that senses all the doors? Perhaps even the "door open" light on the instrument panel since that clearly illuminates when the doors OR the hatch is open.
Much obliged if anyone can point me to a wire, or a schematic.
Regards
-Ted
Old Sep 18, 2006 | 12:33 PM
wjwerdna's Avatar
heres the interior lighting schematics from a 1999 SR5
Old Sep 18, 2006 | 12:37 PM
wjwerdna's Avatar
i lied... attachements didnt work, here they are.... (clickable)
Old Sep 18, 2006 | 09:21 PM
tedp's Avatar
thanks!! time to disassemble again
Old Sep 19, 2006 | 11:59 AM
profuse007's Avatar
DOOR TRIGGER LIGHT GREEN/BLACK (-) will catch all doors, except for cargo hatch.
THE DOOR TRIGGER WIRE IS LOCATED BEHIND THE DRIVERS SIDE JUNCTION BLOCK, IN A 13-PIN PLUG.
Old Sep 20, 2006 | 08:57 PM
arjan's Avatar
Most alarms have a channel for an hood pin, that's the one I used for the rear hatch wire.
Old May 10, 2010 | 08:54 PM
Broncosi's Avatar
I hate to revive this dead thread buuttt. I am trying to wire courtesy lights under my '98 4runner and need a wire to tap so they come on when the doors open. I also wanted to know how I should wire in a switch that could 'override' the door trigger, so I could turn the lights at anytime when the doors are closed.
Any help appreciated!!
Old May 10, 2010 | 09:01 PM
Elton's Avatar
i just wired mine into the light around the key hole
Old May 10, 2010 | 09:02 PM
Broncosi's Avatar
ok great so if i tap into that ring, it will give my relay power when the driver door is opened?
Old May 10, 2010 | 09:05 PM
Elton's Avatar
it should but im no expert
Old May 10, 2010 | 09:08 PM
Broncosi's Avatar
ok i think i will tap into the dome light instead to get lights on when any door is opened. That or the 'open door' light on the dash maybe? Thanks for your help btw!
Jun 1, 2021 01:51 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
toyota32
Jul 6, 2015 05:42 PM
colinmil
Jul 6, 2015 04:03 PM
