97 3.4l 4R overheating
Old 02-12-2015, 07:06 AM
fierohink's Avatar
Question 97 3.4l 4R overheating
Coming home from work today my CEL came on. Stopped at advanced auto to scan and came up with #3 misfire historical and current codes. Sounded right as I noticed a stutter coming off idle this morning.
Reset the code.
Left the store. Started off to my next stop and temp began rising quickly. Pulled off. Shut everything down before I got to the red. Popped the hood.
Rad cap felt warm but not hot. Coolant still in res. Upper rad hose was hot and hard.
Took care of business @ 2nd stop, maybe 20 minutes. Started the truck. Temp just below middle. Drove a few miles and started to heat up again.
No other issues over the life of the vehicle.
Does this sound like a stuck thermostat? Or should I prepare myself for more?
Old 02-12-2015, 08:46 AM
vasinvictor's Avatar
Did you feel the lower rad hose?
Old 02-12-2015, 09:04 AM
fierohink's Avatar
I didn't.
Old 02-12-2015, 09:21 AM
Of course you can pull the t stat housing off the boil the thermostat and see if it's opening. Is your rad cap sealing well?
Old 02-12-2015, 09:24 AM
JasonYota's Avatar
X2. If you boil it in glass make sure it's Pyrex, ask me how I know.
Old 02-12-2015, 09:27 AM
That sounds like a real bad time. I just use a pot on the stovetop.
Old 02-12-2015, 11:41 AM
fierohink's Avatar
I pulled the t-stat and boiled it. First time to 180* no open, continued to boil then it opened. after that it would open and close at 180* like it was supposed. So that was gummed up and got replaced.
Now I'm waiting on the parts guy for antifreeze to make sure that was the only issue.
Old 02-13-2015, 12:55 PM
fierohink's Avatar
Update, refilled with coolant and now i have a fair amount of steam from the tailpipe. Replaced the #3 plug and it was damp with a mostly oil and an odor of coolant.
Hesitation went away but i still have the steam.
It looks like I have a head gasket job in my future.
Team420
01-12-2021 04:57 PM
S14SEAN
9
03-13-2012 08:53 PM
CodyX36
78
08-21-2010 08:07 AM
Pozi
13
08-10-2006 12:28 AM
reece36
12
08-23-2005 07:12 AM
Quick Reply: 97 3.4l 4R overheating
