96 Timing Chain Replacement???
Old Sep 29, 2004 | 09:45 PM
994runner's Avatar
We just got a 96 4Runner with the 4 cyl engine that we are going to try to sell to make money. It has 300000km on it and we don't know when the timing belt was done last so we want to do it before we sell it. First, what is the official name of the 4 cyl in this truck (ie the older ones were 22RE's). And how big of a job is this, anything to watch out for? Any step by step instructions online? I did the belt, water pump, etc in my 99 V6 Runner myself so I do have a little mechanical skill, just have never worked on one of these newer Toyota 4 cyls.I tried a search and found lots of info on the older vehicle timing chans but not ,much on the newer stuff. Thanks!
Old Sep 30, 2004 | 12:44 AM
kevin444's Avatar
That 96 4runner has the 2.7L 3rz-fe motor. Yes the 4cyl uses chain instead of belts. GL
Old Sep 30, 2004 | 05:35 AM
superjoe83's Avatar
the 2.7 has 2 balance shafts that are driven by a second chain, you should replace both chains, Ive heard that it can be a little tricky to get things timed correctly, but if you've done a belt before a chain isn't much different, just more messy
Old Sep 30, 2004 | 05:39 AM
MTL_4runner's Avatar
300k KM is only like 190k miles which is not alot for a timing chain (they should last up into the 300k mile mark)
Old Sep 30, 2004 | 06:54 AM
994runner's Avatar
Really, timing chains should be good up until 300000 miles??? Can anyone else confirm this???
Old Sep 30, 2004 | 06:26 PM
994runner's Avatar
bumps
Old Sep 30, 2004 | 06:53 PM
SpecializedBrder's Avatar
MY 2.7 has 184,000 miles and is still movin along just fine. I wouldn't worry about the timing chain.
Old Oct 1, 2004 | 12:20 PM
994runner's Avatar
bumped
fasterspider
Oct 6, 2015 10:24 AM
Ichneumon
Sep 27, 2015 04:21 PM
Badger62811
Jun 26, 2015 09:26 PM
Taz22R
Jun 21, 2015 04:44 PM
paxanders
Jun 21, 2015 06:29 AM
