96 4runner airbox noise?
Old 07-02-2014, 09:37 PM
mojo4x420's Avatar
I'm looking at buying a friends truck.
96 4runner
2.7l
auto
It's making a strange warbling noise from the hose that goes into the airbox. I believe it's the charcoal canister that the hose connected to, but I could be wrong on that. I don't have the truck handy to check again.
After the vehicle is warm, it makes the noise at idle and at very low revs. It's probably slightly lower pitched then the lights warning noise, but loud enough that you can hear it clearly in the cab. A very clear, oscillating, warbly, wobbly, howly noise. and it's definitely coming from the small hose that connects into the airbox.
Any thoughts? Is that a normal noise for the 3rzfe? Too loud?
Truck drives great besides that and looks like a good buy.
thanks!
Old 07-03-2014, 11:04 AM
wyoming9's Avatar
Red face
Are you sure it is what you think??
I don`t have one of those in front of me But I never heard a noise like that from any Evap system
Is there a hole in the hose?? What if you unplug the hose??
Old 07-03-2014, 12:55 PM
vasinvictor's Avatar
Is there a rodent in there? I kid. Are all the resonant tubes on it? Does it look like anything has been removed from the airbox or plenum tube that connects to the throttle body?
Old 07-21-2014, 02:59 PM
mojo4x420's Avatar
Hi, Sorry about the delay. The trucks my daily driver now.
Looks like the tubes are all there. I recorded a short video.
You can hear the noise go away when I pinch the tube.
After you turn off the vehicle, you get a buzzing that's identical to
https://sites.google.com/site/bugeye...unner-evapbuzz
Old 07-21-2014, 04:49 PM
rworegon's Avatar
Maybe Habanero's moo box fix (post 1097) would solve it or maybe not:
https://www.yotatech.com/forums/f200...l#post52041688
Old 09-29-2014, 12:44 PM
mojo4x420's Avatar
I did the moobox fix. I found a wrecked evap canister and broke off the resonator piece with some easily repairable damage. Buzz is gone, but it didn't change the warble noise.
I replaced some suspect vacuum lines and it quieted the noise down slightly, but it's still very audible when it kicks in.
mskalmus
05-28-2017 07:51 AM
MTLroadierunner
07-15-2015 12:58 PM
razorman8669
07-12-2015 12:13 PM
Jonny246
07-12-2015 04:51 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: 96 4runner airbox noise?
