96 4runner 4 cyl engine noise & 'lurch'
Old 06-21-2004, 10:08 AM
unSane's Avatar
So I picked up an 'as is' 4runner SR5 4 cylinder last week for a decent price from a dealer here in Ontario. 158,000 Kms on the clock, seems to have been decently maintained (dealer had some history, 1 owner, newish looking wires and hoses, nice tires, etc). Changed all fluids and did a safety check... everything is fine. In fact I spent a grand total of $100 to get it on the road. Just two questions:
1) The engine 'roars' a little under heavy acceleration at low RPM. It sounds like it might be a muffler problem, but everything looks intact. Could be manifold, manifold gasket? There's also a very slight 'tick tick' audible inside the cabin when idling, can't hear it with the hood off... I know this also can signal a crack in the manifold... any comments?
2) When I come to a halt at a stop sign and wait with my foot on the brake, after a couple of seconds there's a slight lurch as if the truck wants to go forwards. In fact it will do just that if I have my foot very lightly on the brake. This is also sometimes accompanied by a 'clunk'. I just changed the transmission fluid so the levels should be fine... any ideas?
Cheers all.
Old 06-21-2004, 06:04 PM
pfbmgd's Avatar
I get the same clunk .I read some where that this is normal for this truck .I just can`t remember where .
I would be intrested in what type of gas mileage you get from your 4 cylinder.I`m getting a 23 mpg combined city/highway .
Old 06-21-2004, 08:09 PM
FUZION's Avatar
I get 17 mpg on my 97 4cyl
Old 06-21-2004, 09:29 PM
calg3's Avatar
The roar you hear could be the engine fan, I hear it on mine especially when the A/C is running. Which brings me to your #2-mine will surge when I am stopped at a red light, for example, also when the A/C is on. But not when the A/C is off. Check and see if your A/C is on, it turns on automatically when you have it set to defrost even if you have the A/C switch off. The tick could be a crack in your exhaust manifold, it is very common. Remove the heat shield and give it a visual inspection. LC Engineering has the cure for the cracked exhaust manifold and the fan.
Old 06-22-2004, 01:35 AM
pfbmgd's Avatar
17 MPG Ouch !
voiddweller
19
05-02-2016 09:10 PM
Outsane
07-15-2015 05:01 AM
puddlepirate
06-30-2015 05:08 PM
Old Red 94
06-16-2015 08:32 PM
Quick Reply: 96 4runner 4 cyl engine noise & 'lurch'
