95 taco standard cab 4x4 leaf springs
Old 03-07-2015, 07:06 AM
BigHoss_27's Avatar
Any one have the part number to these and if both sides use the same springs cause I thought my shocks and struts were bad cause my truck had a lean to it so I replaced them and it still leaning in my opinion pretty bad to the driver side and I have no idea what to do
Old 03-09-2015, 08:18 AM
wyoming9's Avatar
Red face
Do you Really want a Toyota Part #??
Just so you know The Toyota Springs are @ $660.00 each add the hardware.
If your looking for Stock Replacement springs I use General Spring out of Kansas City.
Much Cheaper and I have been happy with service and quality.
Old 03-13-2015, 12:13 AM
BigHoss_27's Avatar
Not really sure how to know if ones bad
Old 03-14-2015, 12:27 AM
wyoming9's Avatar
Red face
You would look for any broken leafs .
sometimes the broken leaf will move one way or the other making it easy to see.
One side of truck sitting lower then the other when parked on a level surface.
Sometimes one or both springs just wear out and go flat from use and age.
What leads you to think you have a broken or bad spring??
Old 03-14-2015, 05:49 AM
BigHoss_27's Avatar
The lean on the truck but both rear leafs were replaced 25000 ago
Old 03-15-2015, 11:57 PM
wyoming9's Avatar
Red face
Do you load the truck beyond it`s rated load capacity all the time??
It is possible you got a bad spring that the temper was not correct.
Either of these could be your problem.
Old 03-16-2015, 07:47 AM
BigHoss_27's Avatar
No most of the time it stays empty with the exception or a truck toolbox but it don't have much in it
mdev126
10-04-2015 04:48 AM
88sasturbotoy
08-11-2015 01:56 AM
hexrain
07-12-2015 01:13 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: 95 taco standard cab 4x4 leaf springs
